Errors
Fri Jan 07, 2022 3:49 pm
Patje73 offline
Errors
I am having the same issues with this plugin:
Sonos Error versionCheck: Unable to reach the version server.
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos 6.indigoPlugin/Contents/Server Plugin/Sonos.py", line 281, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos 6.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2294, in closedPrefsConfigUi
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos 6.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2263, in getReferencePlayerIP
AttributeError: 'NoneType' object has no attribute 'pop'
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 47, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos 6.indigoPlugin/Contents/Server Plugin/Sonos.py", line 374, in runConcurrentThread
TypeError: int() argument must be a string or a number, not 'NoneType'
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tried to re-install but this does not help.
After a re-load I received this message:
Warning process (pid 39453) failed to quit after polite request -- forcing it to quit now
The again: Sonos Error Error in plugin execution InitializeMain:
File "plugin.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 31, in <module>
File "./lib/twisted/internet/reactor.py", line 38, in <module>
File "./lib/twisted/internet/default.py", line 56, in <module>
File "./lib/twisted/internet/default.py", line 50, in _getInstallFunction
File "./lib/twisted/internet/selectreactor.py", line 15, in <module>
File "./lib/zope/interface/__init__.py", line 53, in <module>
File "./lib/zope/interface/interface.py", line 656, in <module>
File "./lib/zope/interface/interface.py", line 637, in __new__
TypeError: multiple bases have instance lay-out conflict
Not sure what I can try next..
Patrick
[MODERATOR NOTE]: moved to the Sonos plugin forum since it's an error specific to the Sonos plugin. It is not the same issue as where it was originally posted...
Wed Jun 01, 2022 10:33 pm
Bleasel offline
Re: Errors
I am getting the same error with the Sonos plugin after upgrading to 2022.1
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 26, in <module>
ImportError: No module named AppKit
