Album Art Folder
Sat Feb 01, 2020 10:45 pm
hdfreak offline
Album Art Folder
Hey All,
Trying to link album art to a control page. The Sonos plugin creates a "sonos" folder under "/Library/Application Support/Perceptive Automation/images" but never populates it with any files. If I delete the folder, it puts it right back upon the first play action.
Using the latest plugin (1.0.16).
Brian
Sat Feb 22, 2020 11:20 am
Re: Album Art Folder
Sorry - meant to reply to this a long time ago, but it slipped through the cracks. Cover art is populated to that location, but it's not always populated. For example, when I'm playing music from my iTunes library, the cover art file is populated. This URI is placed in the ZP_ART state:
Screen Shot 2020-02-22 at 11.01.44 AM.png (74.87 KiB) Viewed 1020 times
When I'm playing something from Pandora, the cover art file is not populated. When Pandora is playing, the ZP_ART state is empty, but I can see a reference to the mp3 file in the ZP_CurrentTrackURI state (I suspect the cover art is embedded in the referenced mp3 file, but the plugin may not have access to it). In its place, the plugin uses a placeholder image that it ships with:
Screen Shot 2020-02-22 at 11.07.35 AM.png (27.96 KiB) Viewed 1020 times
To display the image file (when it's available), display it as a refreshing image URL with the following structure (note that spaces have been replaced by '%20':
file:///Library/Application%20Support/Perceptive%20Automation/images/Sonos/Workshop_art.jpg
I have had it on my to-do list to see if I can find a way to get the Pandora cover art to display, but it's never boiled to the top of the list for me. Maybe someone else has figured this out by now. I don't know this as fact, but it could be that changes to the Sonos API have broken something, because I could swear that I've been able to display Pandora cover art in the past.
Wed Feb 26, 2020 2:13 pm
mundmc offline
Same here- I KNOW I have seen Pandora cover art in the past. I briefly looked at the lastfm api for searching for cover art based on album and band names, and it seemed doable.
Sat Mar 28, 2020 9:49 am
nlagaros offline
I just did some testing with Pandora and the album art appears to be working. Are you still having this issue?
Sat Mar 28, 2020 11:09 am
mundmc offline
Hi Nick- I am! Any specific log stuff you would like to see?
Sat Mar 28, 2020 1:11 pm
jltnol offline
as a side question, is this refreshing image available in iTunes?
Sun Mar 29, 2020 6:33 am
Hey Nick. I just updated to the latest version and Pandora cover art now works for me. Thanks for continuing to support this awesome plugin.
As a side note, I still get "unable to reach the version server" errors upon startup, which I suspect is a result of not being able to reach the URL specified in __init__. So what I've done is comment out the following lines to silence the errors.
plugin.py
25
35
62
Sonos.py
289
372
Could you knock those out permanently in a future version? Thanks!
Mon Mar 30, 2020 3:34 pm
nlagaros offline
Can you try the latest version of the plugin and see if this issue still persists. If so, let's look at the XML messages coming in when you switch to a Pandora station. That should give us some clue. Thanks.
Mon Mar 30, 2020 9:57 pm
mundmc offline
Thanks Nick- I didn’t realize I wasn’t on 1.0.17 (i had 1.0.16)!
That did the trick, and thanks again for making an essential part of my family’s HA experience :)
