Sonos Plugin elapsed time
Mon Jun 18, 2018 6:45 pm
philipbasile offline
I need some python help. Im trying to calculate percent elapsed time for a song in the songs plugin.
The current attribute REMAINING actually counts up from 0:00 to the DURATION of the song.
I'd like to move the REMAINING time into a variable called ElapsedTime and then calculate remaining time.
I got started with the following but I'm already getting errors.
varMusicElapsedTime = indigo.variables[1086500855]
varMusicRemainingTime = indigo.variables[1086500892]
varSonos = indigo.devices[1475651238]
varMusicElapsedTime.value = varSonos.Remaining
Indigo is complaining about the attribute REMAINING not existing.
Mon Jun 18, 2018 8:16 pm
Re: Sonos Plugin elapsed time
Firstly, Indigo variables are stored as strings so you need to convert them to numbers (I assume they're integers here):
varMusicElapsedTime = int(indigo.variables[1086500855])
varMusicRemainingTime = int(indigo.variables[1086500892])
Secondly, I believe that you're looking for a device state (not a device property), which is referenced like this (note that I also removed the dot from your last variable name):
varMusicElapsedTimeValue = varSonos.states['Remaining']
If you post the dict of your device (be sure to mask any sensitive data) it would help to diagnose your issue.
Tue Jun 26, 2018 7:39 pm
Thank You !
How do I post the dict (dictionary ?)
Tue Jun 26, 2018 8:08 pm
I could do this in VB is a few minutes, I hate not knowing python syntax !
Here is what I have...
I get an error on the last line "key remaining not found in dict"
varMusicElapsedTime =indigo.variables[1086500855] # "MusicElapsedTime"
varMusicRemainingTime = indigo.variables[1552641211] # "MusicRemainingTime"
varSonos = indigo.devices[1475651238] # "Sonos"
varMusicElapsedTime = varSonos.states['remaining']
Here is what I'm trying to do
I'd like to first put the Remaining time (which is really the elapsed time) into a correctly named variable, varElapsedTime, in secs.
Then I need to put the song Duration into a variable varDuration in secs
Then I need to convert the now correctly named varElapsedTime to a percentage of a 360 degree circle where 360 degrees is the duration of the song.
Then I need the varElapsedDegrees to be on 15 degree boundries since my elapsed graphics for my control page are on 15 degree increments
Here is the math
varDegrees = (360 * varElapsedTime) / varDuration
varDegrees = Int(varDegrees / 15) * 15
I there a time function to convert to secs ?
Thanks for the help
Philip
Wed Jun 27, 2018 1:39 am
to get the variable as a number:
valueAsString = varMusicElapsedTime.value
valueAsNumber = int(valueAsString)
in one line:
valueAsNumber = int(indigo.variables[1086500855] .value)
then normal math
eg
newValue = valueAsNumber / 60
to update a variable:
indigo.variable.updateValue(1086500855, value= str(newValue))
check out this page:https://wiki.indigodomo.com/doku.php?id=indigo_7_documentation:plugin_scripting_tutorial
hope that helps
Wed Jun 27, 2018 7:46 pm
Thank You Dave and KW for all the help getting me on the right track!
Here is what I ended up with...
I snuck some code off a python site for converting H:M:S to secs and it all works now.
import datetime
varMusicDuration = varSonos.states['ZP_DURATION']
varMusicElapsedTime = varSonos.states['ZP_RELATIVE']
varMusicElapsedSecs = sum(x * int(t) for x, t in zip([3600, 60, 1], varMusicElapsedTime.split(":")))
varMusicDurationSecs = sum(x * int(t) for x, t in zip([3600, 60, 1], varMusicDuration.split(":")))
varMusicRemainingSecs = varMusicDurationSecs - varMusicElapsedSecs
varMusicDegrees = (360*varMusicElapsedSecs)/varMusicDurationSecs
varMusicDegrees = int(varMusicDegrees/15)*15
indigo.variable.updateValue(1086500855, str(varMusicElapsedTime))
indigo.variable.updateValue(790247935, str(varMusicDuration))
indigo.variable.updateValue(419456527, str(varMusicDegrees))
