Sonos error : Error in plugin execution runConcurrentThread:
Thu Dec 12, 2019 12:25 pm
Colly offline
Re: Sonos error : Error in plugin execution runConcurrentThr
Is there any chance one of the Sonos’ has changed its IP address? I know at some stage in the past I had loads of log errors due to an incorrect IP address. The plugin is working perfectly for me on both latest OS and Indigo.
Thu Dec 12, 2019 12:34 pm
wideglidejrp offline
Good suggestion. I just ran IP Scanner and see some irregularities between what it found and what I have in Indigo devices. Sorting this out will be my afternoon project. Thanks for posing this question.
John R Patrick
Author of
Home Attitude
Thu Dec 12, 2019 1:13 pm
I have 11 Sonos devices. Each has an IP reserved in Google WiFi mesh network. I was able to reconcile what IP Scanner found on the network with what I have for the seven devices in Indigo. The four not in Indigo are the Boost, the SUB, and the two rear speakers in theatre. Thanks again for the suggestion, but IP addresses do not seem to be the problem.
John R Patrick
Author of
Home Attitude
Thu Dec 12, 2019 11:58 pm
siclark offline
I have a trigger that counts the number of Sonos errors in there log then restarts the plugin after a set number.
Fri Dec 13, 2019 7:30 am
That sounds like a really great idea. Can you share the details on how you did that?
John R Patrick
Author of
Home Attitude
Fri Dec 13, 2019 8:14 am
siclark offline
Trigger on error in log when description (I think) starts with Sonos. Action to increment a variable by 1
Trigger 2 when variable > X action to restart plugin and reset variable.
Can't quite remember the trigger on error pet but can look tomorrow if you can't figure it out
