Sonos error : Error in plugin execution runConcurrentThread:
Wed Nov 07, 2018 10:58 am
OjisanSeiuchi offline
Re: Sonos error : Error in plugin execution runConcurrentThr
The problem originates at line 499 in Sonos.py. I'm not the developer and I haven't delved into the code but the problem is with an unhandled exception that gets propagated back up to the host. You can suppress catch the exception and just ignore it. I haven't seen any downside (yet.)
def socoSubTest(self):
      for item in self.deviceList:
         dev = indigo.devices[item]
         subStatus = True
            if self.soco_sub[dev.id]['avTransport'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: avTransport subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if self.soco_sub[dev.id]['renderingControl'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: renderingControl subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if self.soco_sub[dev.id]['zoneGroupTopology'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: zoneGroupTopology subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if self.soco_sub[dev.id]['queue'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: queue subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if self.soco_sub[dev.id]['groupRenderingControl'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: groupRenderingControl subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if self.soco_sub[dev.id]['contentDirectory'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: contentDirectory subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if self.soco_sub[dev.id]['groupManagement'].is_subscribed != True:
               self.plugin.errorLog("[%s] [%s]: groupManagement subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
               subStatus = False
            if int(dev.pluginProps["model"]) in [SONOS_CONNECT, SONOS_CONNECTAMP, SONOS_PLAY5]:
               if self.soco_sub[dev.id]['audioIn'].is_subscribed != True:
                  self.plugin.errorLog("[%s] [%s]: audioIn subscription failed.  Resubscribing..." % (time.asctime(), dev.name))
                  subStatus = False
         except:
            #self.plugin.errorLog("Error in socoSubTest");
            pass
         if subStatus == False:
            self.socoUnsubscribe (dev)
            self.socoSubscribe (dev)
Sat Dec 29, 2018 9:17 pm
philipbasile offline
Nick,
Event check interval is the default... 15
I have the same error and non of my control pages are working.
Started plugin "Sonos 1.0.12"
Sonos Your plugin version, v1.0.12, is current.
Sonos Loaded Sonos Favorites... [14]
Sonos Loaded Playlists... [2]
Sonos Loaded RadioTime Favorite Stations... [0]
Sonos Serving HTTP Streamer on 192.168.2.11 [0.0.0.0], port 8888
Sonos Error [Sat Dec 29 22:15:20 2018] SiriusXM SessionID error, check credentials
Sonos Loaded Polly Voices... [57]
Sonos [Sat Dec 29 22:15:20 2018] Processed plugin preferences.
Sonos Loaded Apple Voices.. [67]
Sonos SSDP Listener Started...
Sonos Adding ZonePlayer: 192.168.2.36, RINCON_949F3E2363E401400, Sonos
Sonos Error exception in deviceStartComm(Sonos): need more than 0 values to unpack
Sonos SoCo Reactor Ignition...
Dec 29, 2018, 10:15:36 PM
Sonos Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 375, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 499, in socoSubTest
KeyError: (1475651238,)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tue Jan 29, 2019 10:05 pm
dnomode offline
I also have the same problem :(
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 375, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 499, in socoSubTest
KeyError: (1847837881,)
Sun Apr 14, 2019 4:09 am
Nine offline
Same here :cry:
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 369, in runConcurrentThread
TypeError: int() argument must be a string or a number, not 'NoneType'
Restart of plugin and Indigo (!) did not help.
Sun Apr 14, 2019 4:29 am
Nine offline
v 1.0.15 fixes it :-) http://www.indigodomo.com/pluginstore/147/
unfortunately 1.0.12 does not show, that there is an update...
Sun Apr 14, 2019 12:59 pm
dnomode offline
I just updated to 1.0.15 and I'm getting the bellow errors:
  Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Family Room]: renderingControl subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Family Room]: zoneGroupTopology subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Family Room]: queue subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Family Room]: groupRenderingControl subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Family Room]: contentDirectory subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Family Room]: groupManagement subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: avTransport subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: renderingControl subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: zoneGroupTopology subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: queue subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: groupRenderingControl subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: contentDirectory subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: groupManagement subscription failed.  Resubscribing...
   Sonos Error                     [Sun Apr 14 14:50:49 2019] [SONOS Office]: audioIn subscription failed.  Resubscribing...
Any ideas?
Thanks for the update.
Edmond
Mon May 06, 2019 8:39 pm
farberm offline
I am getting similar errors also ..Resubscribing..
Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos - Living Room Playbar]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Attic Bedroom]: audioIn subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Kitchen]: audioIn subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Master Bedroom]: audioIn subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Office]: audioIn subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Pool]: audioIn subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Theater Room]: audioIn subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: queue subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: groupManagement subscription failed. Resubscribing...
Sonos Error [Mon May 6 22:33:03 2019] [Sonos Workout Room]: audioIn subscription failed. Resubscribing...
Tue May 14, 2019 6:22 am
MartinG offline
Similar for me unfortunately.
Problems started when I changed the IP address of my reference player. The plugin didn't seem to recognise the change, and continued looking at the old IP addresses. Deleting the plugin and the Sonos devices, then reinstalling 1.0.15, doesn't seem to have solved anything unfortunately.
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Sonos 13.11.37.indigoPlugin/Contents/Server Plugin/Sonos.py", line 371, in runConcurrentThread
Mon Jul 22, 2019 9:35 am
wideglidejrp offline
I am getting a lot of Sonos errors and cannot figure out the root cause. I have reloaded plugin (1.0.15) and rebooted iMac, Any ideas appreciated.
Jul 22, 2019 at 6:18:45 AM
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 377, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 501, in socoSubTest
KeyError: (1229441052,)
John R Patrick
Author of
Home Attitude
Sat Sep 14, 2019 7:38 am
jens offline
Get this types of error´s
KeyError: (1159594222,)
Indigo Cocoa client connected
Any type of solotion?
Best Regards Jens
Mon Sep 16, 2019 6:42 am
Every day I am getting a log full of Sonos Errors. If I reload the plugin, it cures the problem for a while, but then it happens again. Has anyone else had this problem? I don't know where to start to solve this. Following is a sample of what I am getting.
2019-09-15 18:53:47.902 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: avTransport subscription failed. Resubscribing...
2019-09-15 18:53:47.902 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:53:47.902 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:53:47.902 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: queue subscription failed. Resubscribing...
2019-09-15 18:53:47.902 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:53:47.902 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:53:47.903 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Kitchen]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:53:47.909 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: avTransport subscription failed. Resubscribing...
2019-09-15 18:53:47.909 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:53:47.910 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:53:47.910 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: queue subscription failed. Resubscribing...
2019-09-15 18:53:47.910 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:53:47.910 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:53:47.910 Sonos Error [Sun Sep 15 18:53:47 2019] [Sonos - Playbar]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:54:01.348 Sonos Error [Sun Sep 15 18:54:01 2019] ZonePlayer: Sonos - Great Room has fallen off the network.
2019-09-15 18:54:01.348 Sonos Error [Sun Sep 15 18:54:01 2019] Resubscription due to timeout for ZonePlayer: Sonos - Great Room
2019-09-15 18:54:01.356 Sonos Error [Sun Sep 15 18:54:01 2019] ZonePlayer: Sonos - Kitchen has fallen off the network.
2019-09-15 18:54:01.357 Sonos Error [Sun Sep 15 18:54:01 2019] Resubscription due to timeout for ZonePlayer: Sonos - Kitchen
2019-09-15 18:54:01.361 Sonos Error [Sun Sep 15 18:54:01 2019] ZonePlayer: Sonos - Mbath has fallen off the network.
2019-09-15 18:54:01.361 Sonos Error [Sun Sep 15 18:54:01 2019] Resubscription due to timeout for ZonePlayer: Sonos - Mbath
2019-09-15 18:54:01.368 Sonos Error [Sun Sep 15 18:54:01 2019] ZonePlayer: Sonos - MBR has fallen off the network.
2019-09-15 18:54:01.369 Sonos Error [Sun Sep 15 18:54:01 2019] Resubscription due to timeout for ZonePlayer: Sonos - MBR
2019-09-15 18:54:01.376 Sonos Error [Sun Sep 15 18:54:01 2019] ZonePlayer: Sonos - Office has fallen off the network.
2019-09-15 18:54:01.376 Sonos Error [Sun Sep 15 18:54:01 2019] Resubscription due to timeout for ZonePlayer: Sonos - Office
2019-09-15 18:54:01.384 Sonos Error [Sun Sep 15 18:54:01 2019] ZonePlayer: Sonos - Playbar has fallen off the network.
2019-09-15 18:54:01.385 Sonos Error [Sun Sep 15 18:54:01 2019] Resubscription due to timeout for ZonePlayer: Sonos - Playbar
2019-09-15 18:54:02.989 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: avTransport subscription failed. Resubscribing...
2019-09-15 18:54:02.989 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:54:02.989 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:54:02.990 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: queue subscription failed. Resubscribing...
2019-09-15 18:54:02.990 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:54:02.990 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:54:02.990 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Great Room]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:54:02.995 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: avTransport subscription failed. Resubscribing...
2019-09-15 18:54:02.995 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:54:02.995 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:54:02.995 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: queue subscription failed. Resubscribing...
2019-09-15 18:54:02.995 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:54:02.996 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:54:02.996 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Kitchen]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Mbath]: avTransport subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Mbath]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Mbath]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:02 2019] [Sonos - Mbath]: queue subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Mbath]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Mbath]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:54:03.000 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Mbath]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:54:03.005 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: avTransport subscription failed. Resubscribing...
2019-09-15 18:54:03.005 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.005 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:54:03.005 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: queue subscription failed. Resubscribing...
2019-09-15 18:54:03.005 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.006 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:54:03.006 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - MBR]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:54:03.011 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: avTransport subscription failed. Resubscribing...
2019-09-15 18:54:03.011 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.011 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:54:03.011 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: queue subscription failed. Resubscribing...
2019-09-15 18:54:03.011 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.011 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:54:03.012 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Office]: groupManagement subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: avTransport subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: renderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: zoneGroupTopology subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: queue subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: groupRenderingControl subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: contentDirectory subscription failed. Resubscribing...
2019-09-15 18:54:03.046 Sonos Error [Sun Sep 15 18:54:03 2019] [Sonos - Playbar]: groupManagement subscription failed. Resubscribing...
John R Patrick
Author of
Home Attitude
Thu Sep 26, 2019 1:25 pm
jens offline
Same her :(
//JEns
Wed Oct 02, 2019 11:19 am
ryanbuckner offline
I was able to resolve most of my Sonos errors by doublechecking the IP addresses on the speakers using the sonos app. If the wrong IP is listed in the plugin config, errors galore!
Wed Oct 02, 2019 11:38 am
I have found through experimenting that the errors have something to do with grouping. If I want to perform certain actions with a speaker, I first remove it from any groups. Then I perform the action and then regroup. No errors. I can’t explain it exactly.
John R Patrick
Author of
Home Attitude
Thu Dec 12, 2019 11:06 am
The Sonos plugin is without a doubt the most useful plugin for me. I cannot imagine my daily life without it. Music scenes based on time of day, good morning and good night scripts initiating Amazon Polly announcements, and on and on. The plugin has an incredible amount of functionality. I feel a lot of gratitude for has been created. However, the plugin has become unreliable for me. My log is replete with tons of error messages such as the one which is the topic of this thread. The cause may be something I am doing wrong, but I am not able to diagnose the errors. The documentation doesn't explain any warnings or tips to avoid certain errors. The messages don't help much. For example, during the past hour, I have received 20 lines of errors such as below. Are others having similar problems?
Sonos Error UPNP Error: Action Failed
Sonos Error Offending Command -> zoneIP: 192.168.86.71, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetAVTransportURI
John R Patrick
Author of
Home Attitude
