Sonos error : Error in plugin execution runConcurrentThread:
Thu May 03, 2018 1:25 pm
kidney offline
Benn having all sorts of problem since the upgrade....
Sonos Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 375, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 499, in socoSubTest
KeyError: (1556524038,)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sonos SoCo Reactor Ignition...
Running the latest ,12 on mac os X server 10.13.4
Any idea?
Fri May 04, 2018 5:59 am
ryanbuckner offline
Re: Sonos error : Error in plugin execution runConcurrentThr
I'm getting the same error. It started last night
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos 2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 369, in runConcurrentThread
TypeError: int() argument must be a string or a number, not 'NoneType'
Indigo Version: 7.1.1
Sonos Plugin: 1.0.12
Mac OS Sierra: 10.12.6
Sat May 05, 2018 3:21 am
nlagaros offline
In the plugin configuration, what value do you have set for "Event Check Interval"?
Sat May 05, 2018 3:22 am
nlagaros offline
Would you please enable debugging, restart the plugin, and post the output. Thanks.
Any idea?
Sat May 05, 2018 8:30 am
kidney offline
HI!
Look like I found out that one the sonos wasn't responding and also my SiriusXM credential were not right, and that seemed to be causing all the problems.
Since i fixed those 2 issues all seem normal!
Wed May 09, 2018 10:34 pm
kidney offline
now this....
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 369, in runConcurrentThread
Any clue why this?
Thu May 10, 2018 4:09 am
nlagaros offline
kidney wrote:
now this....
Any clue why this?
Thu May 10, 2018 5:54 am
kidney offline
60
Sat May 12, 2018 9:45 am
pbaperez offline
Here is my error..
May 12, 2018, 10:44:09 AM
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 368, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 487, in socoSubTest
KeyError: (1039006437,)
Sat Jun 09, 2018 2:11 pm
noel1983 offline
I'm getting this as well. Log output is
9 Jun 2018 at 21:07:49
KeyError: (594227149,)
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
Any ideas what to do to solve? It's making my log files very untidy! :)
Cheers
Sun Aug 12, 2018 10:17 pm
dking4 offline
I'm getting similar errors after enabling the Sonos plugin and there are no zone players available to the plugin.
Aug 12, 2018 at 8:13:27 PM
Enabling plugin "Sonos 1.0.12"
Starting plugin "Sonos 1.0.12" (pid 63480)
Started plugin "Sonos 1.0.12"
Sonos Your plugin version, v1.0.12, is current.
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 274, in startup
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 150, in makedirs
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 157, in makedirs
OSError: [Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images'
Sonos Using Reference ZonePlayer IP: 172.25.26.116
Sonos Debug zoneIP: 172.25.26.116, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Debug Sonos Favorites: FV:2/8, An Evening In Prague, x-rincon-playlist:RINCON_000E5872256601400#A:GENRE/Classical/Czech%20Television%20Studio%20Orchestra/An%20Evening%20In%20Prague
Sonos Debug Sonos Favorites: FV:2/11, Better Together, x-rincon-cpcontainer:1004206clibraryalbum%3al.NgB2Psz
Sonos Debug Sonos Favorites: FV:2/10, Facing a Task Unfinished (Deluxe Edition), x-rincon-playlist:RINCON_000E588198C001400#A:ALBUMARTIST/Keith%20%26%20Kristyn%20Getty/Facing%20a%20Task%20Unfinished%20(Deluxe%20Edition)
Sonos Debug Sonos Favorites: FV:2/9, Hymns for the Christian Life (Deluxe Version), x-rincon-playlist:RINCON_000E5872256601400#A:ALBUMARTIST/Keith%20%26%20Kristyn%20Getty/Hymns%20for%20the%20Christian%20Life%20(Deluxe%20Version)
Sonos Debug Sonos Favorites: FV:2/12, Lifer, x-rincon-playlist:RINCON_000E58754E7401400#A:ALBUMARTIST/MercyMe/Lifer
Sonos Debug Sonos Favorites: FV:2/7, Live At the Gospel Coalition, x-rincon-playlist:RINCON_000E58754E7401400#A:ALBUMARTIST/Keith%20%26%20Kristyn%20Getty/Live%20At%20the%20Gospel%20Coalition
Sonos Debug Sonos Favorites: FV:2/5, More And More Of You, x-file-cifs://New-Mac-Mini/Music/iTunes/iTunes%20Media/Music/Selah/You%20Amaze%20Us/04%20More%20and%20More%20of%20You.m4a
Sonos Debug Sonos Favorites: FV:2/2, Pass Me Not, x-file-cifs://server/iTunes%20Media/Music/Fernando%20Ortega/Hymns%20of%20Worship/01%20Pass%20Me%20Not.m4a
Sonos Debug Sonos Favorites: FV:2/14, Sing! Live At the Getty Music Worship Conference, x-rincon-playlist:RINCON_000E58754E7401400#A:ALBUMARTIST/Keith%20%26%20Kristyn%20Getty/Sing!%20Live%20At%20the%20Getty%20Music%20Worship%20Conference
Sonos Debug Sonos Favorites: FV:2/0, The Best of the Gaither Vocal Band, x-rincon-playlist:RINCON_000E585BED0401400#A:ALBUMARTIST/Gaither%20Vocal%20Band/The%20Best%20of%20the%20Gaither%20Vocal%20Band
Sonos Debug Sonos Favorites: FV:2/4, The Bible In Living Sound, x-rincon-playlist:RINCON_000E5872256601400#A:ALBUMARTIST/Bible%20In%20Living%20Sound/The%20Bible%20In%20Living%20Sound
Sonos Debug Sonos Favorites: FV:2/1, The Blessed Unrest, x-rincon-playlist:RINCON_000E5872256601400#A:ALBUMARTIST/Sara%20Bareilles/The%20Blessed%20Unrest
Sonos Debug Sonos Favorites: FV:2/6, The Piano Guys Radio, x-sonosapi-radio:radio%3ara.498030399?sid=204&flags=8300&sn=3
Sonos Debug Sonos Favorites: FV:2/15, Unbreakable, x-rincon-playlist:RINCON_000E58754E7401400#A:ALBUMARTIST/Selah/Unbreakable
Sonos Debug Sonos Favorites: FV:2/3, World's Best Praise And Worship, x-rincon-playlist:RINCON_000E58754E7401400#A:ALBUM/World's%20Best%20Praise%20And%20Worship
Sonos Loaded Sonos Favorites... [15]
Sonos Debug Playlist: SQ:13, Accompaniment Hymns, file:///jffs/settings/savedqueues.rsq#13
Sonos Debug Playlist: SQ:2, Choral, file:///jffs/settings/savedqueues.rsq#2
Sonos Debug Playlist: SQ:3, Choral Favorites, file:///jffs/settings/savedqueues.rsq#3
Sonos Debug Playlist: SQ:11, Christmas Vocals, file:///jffs/settings/savedqueues.rsq#11
Sonos Debug Playlist: SQ:8, Gaither Celebration, file:///jffs/settings/savedqueues.rsq#8
Sonos Debug Playlist: SQ:18, Getty Hymns, file:///jffs/settings/savedqueues.rsq#18
Sonos Debug Playlist: SQ:7, Renee's Playlist, file:///jffs/settings/savedqueues.rsq#7
Sonos Debug Playlist: SQ:0, Rutter Favorites, file:///jffs/settings/savedqueues.rsq#0
Sonos Debug Playlist: SQ:6, Sabbath Worship Misc, file:///jffs/settings/savedqueues.rsq#6
Sonos Debug Playlist: SQ:4, Selah, file:///jffs/settings/savedqueues.rsq#4
Sonos Debug Playlist: SQ:5, Selah Favorites, file:///jffs/settings/savedqueues.rsq#5
Sonos Debug Playlist: SQ:14, Strength In Him, file:///jffs/settings/savedqueues.rsq#14
Sonos Debug Playlist: SQ:10, World's Greatest, file:///jffs/settings/savedqueues.rsq#10
Sonos Loaded Playlists... [13]
Sonos Loaded RadioTime Favorite Stations... [0]
Sonos [Sun Aug 12 20:13:41 2018] Processed plugin preferences.
Sonos Serving HTTP Streamer on 172.25.26.5 [0.0.0.0], port 8888
Aug 12, 2018 at 8:14:35 PM
Sonos Manually checking for updates
Sonos Debug versionCheck: Started
Sonos Debug versionCheck: Version Server Url:http://vulture.lagaros.com/IndigoPlugins/Sonos/versionInfoFile.html
Mon Aug 20, 2018 6:48 pm
ryanbuckner offline
60
Thu Aug 30, 2018 1:25 pm
Christian777 offline
Hello!
Im getting the same error:
30/08/2018 14:23:52
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 375, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 499, in socoSubTest
KeyError: (1461228440,)
Is there any solution yet?
Thank you!
Fri Sep 21, 2018 10:26 pm
dliccardo offline
+1 also getting this error...
Wed Nov 07, 2018 4:12 am
OjisanSeiuchi offline
+1 here. Any solution?
