New plugin user having issues.
Wed Dec 20, 2017 10:20 pm
aauno offline
Just installed and configured Sonos plugin. Not sure how to fix the following:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 365, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 482, in socoSubTest
KeyError: (1548838757,)
2017-12-20 14:55:44 Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-20 14:55:54 Sonos SoCo Reactor Ignition...
2017-12-20 14:55:59 Sonos Error Error in plugin execution runConcurrentThread:
Thu Dec 21, 2017 8:19 pm
Re: New plugin user having issues.
I didn't write the Sonos plugin, but I did a little checking on the code anyway.
First thing to do is make sure the Plugin is configured properly. You need to put in the address of a Sonos device (aka ZonePlayer) and the IP address of the Indigo server. Not sure why he has that in the config dialog, he could figure that out in his code. But for now, just put it in.
If that doesn't fix things, the problem you're seeing is probably caused by a bad saved deviceID. I would disable the plugin, then delete all Sonos devices and the plugin preferences. Then re-enable the plugin and try whatever you were doing again.
The preferences are saved in the "Preferences/Plugins" folder under the main Indigo 7 Folder. The name is "com.ssi.indigoplugin.Sonos.indiPref".
Sat Dec 23, 2017 11:47 am
aauno offline
I followed the directions and deleted the entries. Same error still occuring.
Sat Dec 23, 2017 11:53 am
Restart the plugin then post the log file entries from that restart.
Sat Dec 23, 2017 9:27 pm
aauno offline
Dec 23, 2017, 9:52:32 PM
Enabling plugin "Sonos 1.0.9"
Starting plugin "Sonos 1.0.9" (pid 73878)
Started plugin "Sonos 1.0.9"
Sonos Your plugin version, v1.0.9, is current.
Sonos Loaded Sonos Favorites... [6]
Sonos Loaded Playlists... [5]
Sonos Loaded RadioTime Favorite Stations... [7]
Sonos [Sat Dec 23 21:52:34 2017] Processed plugin preferences.
Sonos Loaded Apple Voices.. [64]
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 281, in startup
File "./lib/twisted/internet/posixbase.py", line 382, in listenMulticast
File "./lib/twisted/internet/udp.py", line 178, in startListening
File "./lib/twisted/internet/udp.py", line 198, in _bindSocket
CannotListenError: Couldn't listen on any:1900: [Errno 48] Address already in use. <<<<<====== How to alter port?? aauno
Sonos Serving HTTP Streamer on 68.42.192.152 [0.0.0.0], port 8888
Sonos Adding ZonePlayer: 192.168.3.238, RINCON_5CAAFD418E0601400, Sonos Kitchen
Sonos Error exception in deviceStartComm(Sonos Kitchen): need more than 0 values to unpack
KeyError: (72403889,)
Sat Dec 23, 2017 9:47 pm
You might want to look at this thread: viewtopic.php?f=142&t=18544&hilit=port+1900&start=15#p140988
You can't change port 1900. That's the one it has to listen on. But it appears that something else on your system is using port 1900 exclusively and won't let the Sonos plugin open it in read-only mode.
Figuring out what's grabbing that port is tricky.
Mon Dec 25, 2017 12:35 pm
aauno offline
Port 1900 is currently being used by HDHomeroom. This HDHomerun device is used to translate OTA TV signals to digital and store the TV on my computer for use by Plex TV.
Mon Dec 25, 2017 1:07 pm
Try stopping HDHomeRun, restarting the Sonos Plugin, then starting up HDHomeRun again.
Tue Dec 26, 2017 2:34 pm
aauno offline
Anyone know how to stop HDHomeroom? I forced the task, but it restarted.
I'm trying to understand the following:
aa:~ MacProServer$ sudo lsof -i:1900
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
hdhomerun 111 _HDHomeRun 13u IPv4 0x7524dfb3453177bb 0t0 UDP *:ssdp
aa:~ MacProServer$
Tue Dec 26, 2017 3:38 pm
Make sure you still have the installer for the software handy, then uninstall it. A web search says that there's an uninstaller in the /Users/HDHomeRun directory.
That really just confirms that it's hdhomerun holding that port open, preventing any other processing from opening it. The rest of the line isn't useful (for this).
You posted this before. Nothing new there.
Tue Dec 26, 2017 7:25 pm
aauno offline
I removed HDHomeroom. I restarted my Mac and Sonos connected. I then installed the HDHomerun server without the DVR software, which I understand uses port 1900. After restarting my Mac, Sonos plugin still works. I asked the developer of "Channels" about HDHomerun and he is the one that let me know that HDHomerun DVR service was not required. The HDHomerun staff stated that they don't use port 1900.
This issue has been resolved.
