Error after Sonos Plugin 1.09 Update
Tue Nov 28, 2017 4:32 pm
dhughes offline
Hi! I was on 1.06 and everything was working fine. I then upgraded to 1.09, and now I get this...
Enabling plugin "Sonos 1.0.9"
Starting plugin "Sonos 1.0.9" (pid 65596)
Started plugin "Sonos 1.0.9"
Sonos Your plugin version, v1.0.9, is current.
Sonos Loaded Sonos Favorites... [17]
Sonos Loaded Playlists... [19]
Sonos Loaded RadioTime Favorite Stations... [6]
Sonos Error [Tue Nov 28 17:29:32 2017] Could not retrieve Event Listener IP address.
Sonos Serving HTTP Streamer on 172.16.0.46 [0.0.0.0], port 8888
Sonos Loaded Pandora Stations for ... [95]
Sonos Error [Tue Nov 28 17:29:36 2017] Error getting SiriusXM Channel Lineup
Sonos [Tue Nov 28 17:29:36 2017] Processed plugin preferences.
Sonos Loaded Apple Voices.. [34]
Sonos SSDP Listener Started...
Sonos Adding ZonePlayer: 172.16.0.35, RINCON_B8E937847ACC01400, Bedroom Jilly Sonos
Sonos Error exception in deviceStartComm(Bedroom Jilly Sonos): need more than 0 values to unpack
Sonos Adding ZonePlayer: 172.16.0.36, RINCON_5CAAFD9B83C801400, Family Room Sonos
Sonos Error exception in deviceStartComm(Family Room Sonos): need more than 0 values to unpack
Sonos Adding ZonePlayer: 172.16.0.32, RINCON_000E58353CF601400, Kitchen Sonos
Sonos Error exception in deviceStartComm(Kitchen Sonos): need more than 0 values to unpack
Sonos Adding ZonePlayer: 172.16.0.30, RINCON_000E58318FF401400, Master Bathroom Shower Sonos
Sonos Error exception in deviceStartComm(Master Bathroom Shower Sonos): need more than 0 values to unpack
Sonos Adding ZonePlayer: 172.16.0.34, RINCON_000E58350DC001400, Master Sonos
Sonos Error exception in deviceStartComm(Master Sonos): need more than 0 values to unpack
Sonos Adding ZonePlayer: 172.16.0.23, RINCON_000E58782C8E01400, Office Sonos
Sonos Error exception in deviceStartComm(Office Sonos): need more than 0 values to unpack
Sonos Adding ZonePlayer: 172.16.0.33, RINCON_000E5838970C01400, Pool Sonos
Sonos Error exception in deviceStartComm(Pool Sonos): need more than 0 values to unpack
Sonos SoCo Reactor Ignition...
Sonos Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 365, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 482, in socoSubTest
KeyError: (1018801027,)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tue Nov 28, 2017 4:35 pm
dhughes offline
Re: Error after Sonos Plugin 1.09 Update
Argh. I looked around and looks like I needed to set Listener IP address, which apparently I did not need before. That seems to have solved all errors, except:
Sonos Error [Tue Nov 28 17:34:01 2017] Error getting SiriusXM Channel Lineup
Tue Nov 28, 2017 6:51 pm
SQLGOD offline
Updated to 1.09 and Pandora radio stations won't play, but they seem to load during plugin startup. The Pandora account login and password are correct and I see the stations in the Action Groups section, but errors out when running. I can run the station in the room using the Sonos phone application w/o issue.
Below are the startup log entries:
Nov 28, 2017, 7:46:20 PM
Reloading plugin "Sonos 1.0.9"
Stopping plugin "Sonos 1.0.9" (pid 7665)
Sonos SoCo Reactor Landing...
Stopped plugin "Sonos 1.0.9"
Starting plugin "Sonos 1.0.9" (pid 7839)
Sonos Using Reference ZonePlayer IP: 192.168.1.105
Sonos Loaded Sonos Favorites... [20]
Sonos Loaded Playlists... [6]
Sonos Loaded RadioTime Favorite Stations... [0]
Sonos Serving HTTP Streamer on 192.168.1.99 [0.0.0.0], port 8888
Sonos Loaded Pandora Stations for Pandora... [26]
Trigger trgOrthanc_Restart_tmrOrthanc
Sonos Loaded SiriusXM Stations.. [279]
Sonos [Tue Nov 28 19:46:33 2017] Processed plugin preferences.
Sonos Loaded Apple Voices.. [47]
Sonos Adding ZonePlayer: 192.168.1.103, RINCON_000E58A0F60201400, Den Sonos
Sonos Adding ZonePlayer: 192.168.1.111, RINCON_B8E93780E50801400, Guest Bathroom Sonos
Sonos Adding ZonePlayer: 192.168.1.107, RINCON_000E5828B62601400, Gym Sonos
Sonos Adding ZonePlayer: 192.168.1.102, RINCON_000E5836932001400, Master Bathroom Sonos
Sonos Adding ZonePlayer: 192.168.1.101, RINCON_000E583C29AC01400, Master Bedroom Sonos
Sonos Adding ZonePlayer: 192.168.1.108, RINCON_000E583B1CF801400, Pool Sonos
Sonos ZonePlayer: Pool Sonos, Nothing in Queue to Save
Sonos ZonePlayer: Master Bathroom Sonos, Nothing in Queue to Save
Sonos ZonePlayer: Master Bedroom Sonos, Nothing in Queue to Save
Sonos ZonePlayer: Guest Bathroom Sonos, Nothing in Queue to Save
Sonos ZonePlayer: Gym Sonos, Nothing in Queue to Save
Sonos ZonePlayer: Den Sonos, Nothing in Queue to Save
Sonos LineIn: RINCON_000E583B1CF801400, Audio Component:Pool
Sonos LineIn: RINCON_000E5836932001400, Line-In:Master Bathroom
Sonos LineIn: RINCON_000E583C29AC01400, Audio Component:Master Bedroom
Sonos LineIn: RINCON_000E5828B62601400, Gym AV:Gym
Sonos LineIn: RINCON_000E58A0F60201400, Audio Component:Den
Below is the error message:
Action Group Master Bathroom Sonos Day Scene
Sonos Error UPNP Error: No Such Object
Sonos Error Offending Command -> zoneIP: 192.168.1.102, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Play
Sonos ZonePlayer: Master Bathroom Sonos, Play Pandora: Pandora: QuickMix
Sonos ZonePlayer: Master Bathroom Sonos, Mute Off
Schedule _delayed_action_605
All was working and unchanged prior to upgrade.
Thu Nov 30, 2017 2:15 pm
mvignola29 offline
I am having many various errors version 1.09, Is there a way to download the previous version that worked properly, Any info is appreciated
Michael
Fri Dec 08, 2017 9:58 pm
mclass offline
I am also experiencing problems:
Sonos Error                     exception in deviceStartComm(Shack Play5): need more than 0 values to unpack
KeyError: (4140076,)
Rollback to previous version urgently requested please!
mclass
Sat Dec 09, 2017 5:07 am
koburg offline
I also have a lot of errors the plugin simply hangs/freeze some times and then I cannot do any thing in indigo for a few minutes
the announcement is more bad now than the previous versions.
Sat Dec 09, 2017 7:38 am
roussell offline
You can download previous versions by renaming the download URL:
http://vulture.lagaros.com/IndigoPlugins/Sonos/Sonos.indigoPlugin_1.0.9.zip
http://vulture.lagaros.com/IndigoPlugins/Sonos/Sonos.indigoPlugin_1.0.8.zip
http://vulture.lagaros.com/IndigoPlugins/Sonos/Sonos.indigoPlugin_1.0.7.zip
I don't know how far back they go, however.
Make sure your reference ZP and the new Event Listener IP addresses are set. I also have a habit of just running through all of my Sonos devices' settings after an update to to check/re-save to ensure everything is updated. I also don't use the "reload" function, but rather manually disable-wait-enable to allow processes to fully complete their shutdown procedure. I've noticed that the reload function does not always allow and you will see errors as things try to start back up before they've fully shutdown.
Nick, FWIW, I'm having no problems so far with 1.0.9
9 Sonos zones, Sierra 10.12.6, and Indigo 7.1.1
Speech over Sonos using Apple's Samantha voice.
Terry
Sat Dec 09, 2017 7:48 am
koburg offline
Ok so we can test The older versions. The Announcement are very slow. And Still The mp3 File Announcement is not working sonos Still say File is not correct encoded. The mp3 File plays fine when aded thru folder in The sonos app.
Sat Dec 09, 2017 8:00 am
roussell offline
As a test I set up an action group with a single entry - Speak "This is a test message." to Sonos. I'm seeing consistently 3 seconds between clicking the "Execute Action" button in Indigo and hearing the speech begin. This is local -no cloud- Using Apple's Samantha voice. I prefer local to cloud for all things unless absolutely necessary so I don't use the cloud voices.
What times are you guys seeing and what platform/voice? If you could setup sometime similar to the above to test, perhaps that could help Nick isolate the problem.
Terry
Sat Dec 09, 2017 11:54 am
koburg offline
Terry
I also use Apple voice. About 10 sec to 1 min some Times.
Sun Dec 10, 2017 7:45 am
pgershon offline
Has anyone solved this error message?:
Rest works for me and this error is more of an irritant than an issue, but would be great to make it go away.
Sun Dec 10, 2017 9:23 am
roussell offline
Do you get that when you start the plugin, I don't see that error, and do have Sirius enabled. Do have anything weird, like multiple Sirius accounts in Sonos?
Terry
Sun Dec 10, 2017 12:01 pm
koburg offline
Terry
I have now tried to install this https://github.com/jishi/node-sonos-http-api
on the raspberry pi and it is working super fast with MP3 files no errors at all using port 5005. and have tried this on the Sonos plugin no luck.
I installed this after using hours on my router with no luck. it seems there is something with the plugin in the indigo/Mac environment.
Wed Dec 27, 2017 7:20 pm
kinkyrastaman offline
I'm getting the following error regardless of which version of the plugin i use. and it pops up in the log every 2 mins. any help will be appreciated.
UPNP Error: Action Failed
Sonos Error Offending Command -> zoneIP: 10.0.1.8, soapRoot: /MediaRenderer, soapBranch: /Queue, soapAction: SaveAsSonosPlaylist
Sonos ZonePlayer: MUSIC -MYA'S ROOM, Save Queue: Indigo_RINCON_5CAAFD23DA5201400
Sonos Error UPNP Error: 500
Thu Dec 28, 2017 12:45 am
evansgo offline
I'm getting a log full of this. It seems to be after a mains hit on the Sonos's, the Indigo Mac is on a UPS. If I do a restart on the plugin then it seems fine.
I have setup the listener IP, and not changed anything for some time.
KeyError: (1179189083,)
