I am trying create an action to change the Sonos source to Line-In.
I think I create it okay (Type->Sonos Actions->Music Source->Sonos: Line-In) and set the device to the player whose Line-In I want to use. I did notice that the "Edit Action Setting..." button brought up a "Configure Sonos: Line-In" dialog with a "-select an item -" dialog with no choices.
When I run the action I get:
- Code: Select all
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 156, in actionZP_LineIn
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1326, in actionDirect
TypeError: int() argument must be a string or a number, not 'NoneType'
Any ideas what I have wrong?
Thanks.
