if i'm understanding the logs, it looks like something is barfing on the character (hex) e9, which i think is "small letter e with acute". so that seems like likely to occur given my wife and kids tending to like french music.
here's the logs:
- Code: Select all
Started plugin "Sonos 0.9.5"
Sonos Your plugin version, v0.9.5, is current.
Sonos Adding ZonePlayer: 192.168.1.21, RINCON_000E5884E14401400, BSMT Sonos
Sonos Adding ZonePlayer: 192.168.1.26, RINCON_000E583B117201400, DR Sonos
Sonos Adding ZonePlayer: 192.168.1.12, RINCON_000E58514BFA01400, FR Sonos
Sonos Adding ZonePlayer: 192.168.1.6, RINCON_000E5812AB7E01400, L3O Sonos
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 59, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 307, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2400, in getSonosFavorites
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1028, in parsePoint
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xe9' in position 467: ordinal not in range(128)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
