Here's the log:
- Code: Select all
Starting plugin "Sonos 0.8.33" (pid 94729)
Started plugin "Sonos 0.8.33"
Sonos Error versionCheck: Unable to reach the version server.
Sonos Saved Plugin Configuration
Sonos Loaded Sonos Favorites... [4]
Sonos Loaded Playlists... [2]
Sonos Loaded RadioTime Favorite Stations... [2]
Sonos Loaded IVONA Voices... [51]
Sonos Loaded Sound Files... [1]
Sonos Adding ZonePlayer: RINCON_000E5883F84401400
Sonos Adding ZonePlayer: RINCON_B8E937F8200801400
Sonos Adding ZonePlayer: RINCON_B8E9377DFAB401400
Sonos Adding ZonePlayer: RINCON_B8E937296BB201400
Sonos Adding ZonePlayer: RINCON_B8E937296BD801400
Sonos Error Error getting ZonePlayer data: http://192.168.0.41:1400/status/zp
Sonos Error Offending ZonePlayer: Sonos: Master Bath
Sonos Error ZonePlayer may be physically turned off or in a bad state.
Sonos Error Please disable communications or remove from Indigo.
Sonos Adding ZonePlayer: RINCON_B8E9372A04B601400
Sonos Adding ZonePlayer: RINCON_B8E937A45C3601400
Sonos Subscribing on port: 9999
Sonos SonosEvents INFO: Publishing on port: 9999
Sonos Event Ignition...
Sonos Serving HTTP Streamer on 192.168.0.43 [0.0.0.0], port 8888
Jan 10, 2016, 7:57:16 AM
Sonos Error SOAPSend Error: HTTPConnectionPool(host='192.168.0.41', port=1400): Max retries exceeded with url: /ZoneGroupTopology/Control (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0xb5dae10>: Failed to establish a new connection: [Errno 60] Operation timed out',))
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 346, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 470, in updateZoneGroupStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 532, in SOAPSend
<type 'exceptions.UnboundLocalError'>: local variable 'response' referenced before assignment
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
