Here's debug log:
- Code: Select all
Started plugin "Sonos 0.8.13"
Sonos Your plugin version, v0.8.13, is current.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Reference ZP IP: 10.0.0.55
Sonos Debug Publish/Subscribe Port: 9999
Sonos Debug HTTP Streaming IP: auto
Sonos Debug HTTP Streaming Port: 8888
Sonos Debug Sound File Path:
Sonos Debug Pandora: False
Sonos Debug Pandora User ID:
Sonos Debug Pandora Email Address:
Sonos Debug Pandora Password: *****
Sonos Debug SiriusXM: False
Sonos Saved Plugin Configuration
Sonos Debug Loading Sonos Favorites...
Sonos Debug zoneIP: 10.0.0.55, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 198, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1455, in getSonosFavorites
File "./lib/elementtree/ElementTree.py", line 960, in XML
File "./lib/elementtree/ElementTree.py", line 1242, in feed
<class 'xml.parsers.expat.ExpatError'>: syntax error: line 1, column 0
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
