Pandora
Sat Mar 07, 2015 1:14 pm
bgaiser7 offline
Re: Sonos
Howdy! I've used your plugin for quite a while. LOVE IT!
After the latest update, my Pandora Stations are not showing up in Indigo.
In fact, no matter if I enable or disable Pandora with correct or incorrect username... I get nothing in the log at all about Pandora.
Ideas?
Sat Mar 21, 2015 10:14 am
hdfreak offline
Pandora
I also can't get Pandora stations to come up any more. I'm still on 0.8.7. though.
Is it possible Pandora changed something?
Brian
Sat Mar 21, 2015 11:37 am
roussell offline
Re: Sonos
I'm seeing similar behavior with 0.8.9. Pandora stations either don;t show or if they do, the only show once; meaning the info for an artist doesn't change when the song changes.
Terry
Tue Mar 24, 2015 12:32 pm
nlagaros offline
Re: Pandora
I just posted an update (v0.8.10) that deals with the changes Pandora made to their website.
Tue Mar 24, 2015 1:18 pm
SonosGuy offline
Re: Pandora
There is no configuration option in the plugins menu of the most recent version. plugin just keeps restarting every 20 seconds.
Tue Mar 24, 2015 1:22 pm
nlagaros offline
Re: Pandora
Matt/Jay - This is probably due to my poor coding, but perhaps you can help:
I added a new item to the plugin configuration. Is there a way for users to get to save the new plugin configuration so the plugin no longer bombs out as it starts. As SonosGuy points out, it now will just continue to try to restart itself as it detects a bad configuration file.
Anything I can or should be doing? Thanks.
Tue Mar 24, 2015 1:34 pm
Re: Pandora
This is the sort of thing I do (an example from my Squeezebox plugin):
        if "debugDetailed" in valuesDict:
            squeezeboxGlobal['debug']['debugDetailed'] = valuesDict["debugDetailed"]
            squeezeboxGlobal['debug']['debugDetailed'] = False
So in this example, if "debugDetailed" was the new item (and not set-up) it would default to False.
Not sure if this is your issue though. :)
Tue Mar 24, 2015 5:22 pm
Re: Pandora
I do what John suggested, but use the python dict's get() method which has an optional argument for a default value if the key doesn't exist:
squeezeboxGlobal['debug']['debugDetailed'] = valuesDict.get("debugDetailed", False)
Wed Mar 25, 2015 6:16 am
nlagaros offline
Re: Pandora
Thanks for the tips!
Wed Mar 25, 2015 11:08 am
SonosGuy offline
Re: Pandora
Current version has been updated and works! All good with Pandora!
