Version 0.8.8
Thu Jan 15, 2015 11:48 am
pocster offline
Version 0.8.8
Hey Nick!
No errors. But once the speech has finished the music doesn't resume. Even if I try and start the music manually i.e. via the Sonos app there is no audio (though the track progresses etc. so everything seems fine).
Also, did you add the method so that speech can be created in python i.e. dynamically?
Great stuff though - much appreciated
Cheers
BTW the custom states all ;'filled' in once the speech ended but were still blank before even though track was playing.
Thu Jan 15, 2015 12:05 pm
nlagaros offline
Re: Version 0.8.8
Can you enable the first two debugging options, and send me the output from starting up the plugin? Something is not working properly.
pocster wrote:
Hey Nick!
Cheers
Thu Jan 15, 2015 6:44 pm
DU Lou offline
Re: Version 0.8.8
I can confirm the same behavior Nick. Let me know if you need some debugging from me as well. I am about to turn in for the night but will be happy to provide tomorrow.
~Lou
Thu Jan 15, 2015 7:11 pm
nlagaros offline
Re: Version 0.8.8
I'd love to pick this up tomorrow. Thanks!
Fri Jan 16, 2015 4:53 am
nlagaros offline
Re: Version 0.8.8
I found an issue with initial notifications of ZonePlayer groups. Not sure how to fix it yet, but working on it...
Fri Jan 16, 2015 6:10 am
eme jota ce offline
Re: Version 0.8.8
I'm using the MP3 announcement without the problem reported above.
The radio station that is playing in the Sonos zone before the announcement DOES resume after the announcement finishes.
Fri Jan 16, 2015 6:13 am
nlagaros offline
Re: Version 0.8.8
I believe the issue will occur only when there are predefined groups. All the testing I did involved only one zone and it worked perfectly. Once I created a group, the issue above was uncovered. Always something...
Fri Feb 20, 2015 12:31 pm
nlagaros offline
Re: Version 0.8.8
I just posted an update (v0.8.9) that may actually resolve the group announcement issues. Let me know! Thanks.
Users browsing this forum: Google [Bot] and 5 guests
