Double announcement?
Tue Dec 30, 2014 7:57 pm
edrabbit offline
Updated the Sonos plugin, but I've also been messing with actions, so not sure where to look to fix this.
If I execute a Group Announcement it loops a small amount (about 3 seconds). For example if I do "This is a test", it will speak "This is a test" twice over my Sonos Play:1. If I do "1 2 3 4 5 6 7 8 9" it will speak "1 2 3 4 5 6 7 8 9 1 2 3"
Anyone else running into this? Same thing is actually happening with Group Announcement MP3s as well.
Thu Jan 08, 2015 5:34 am
shapa offline
Re: Double announcement?
I've got similar issue as well
Instead of one announcement, there are 3 (!), one of them is completely wrong and taken from another trigger. Very confusing.
Z-Wave received "Garage Roller Door Sensor" status update is off
Trigger Roller Door Closed
Pushover Debug Garage
Pushover Debug Roller Door Opened
Pushover Debug
Pushover Debug
Sonos Announcement: Ворота в гараже закрылись, Volume: 80
Sonos Announcement Length: 2.052
Pushover Debug Roller Door Closed
Pushover Debug
Pushover Debug
Sonos Announcement: Ворота в гараже открыты, Volume: 80
Sonos Announcement Length: 1.8
Thu Jan 08, 2015 5:55 am
nlagaros offline
I think this happens when the queue repeat option is selected in Sonos. I'll check into it - I think I have to disable that before the announcement and then set it back afterward.
Thu Jan 15, 2015 7:19 am
nlagaros offline
I just posted an update with changes to the Announcement MP3 action that should take care of this issue. If I understand correctly, was the repeating also happening with the Line In Announcement action?
