Sonos speech
Sun Dec 28, 2014 6:03 am
pocster offline
Sonos speech
Hey Nick!
Great update works pretty good!
A few issues. If the sonos is playing audio and then I do speech; once the speech ends it's mute. How do I get it to continue playing i.e. pause, speak, un pause.
Finally - how do I construct a string in python and pass that into sonos to speak? ; rather than a pre-generated string using the menu structure.
Looking good though!!
Happy Xmas and New Year!
Mon Dec 29, 2014 10:25 am
roussell offline
Re: Sonos speech
+1 on constructing a Python string for custom speech. I currently use the variable substitution method but it would nice to inject something directly from Python.
Terry
Mon Dec 29, 2014 10:29 am
pocster offline
Re: Sonos speech
Hey Terry,
I've no idea how you do what you say; can you elaborate please? - assume my knowledge is zero; as that's quite close :-))))
Tue Dec 30, 2014 8:23 am
nlagaros offline
Re: Sonos speech
Jay/Matt - I think this script should work, but am getting an error:
SonosPlugin = indigo.server.getPlugin("com.ssi.indigoplugin.Sonos")
if SonosPlugin.isEnabled():
   SonosPlugin.executeAction("actionZP_announcementMP3", props={'zp1':indigo.devices['Cave'].id,'ttsORfile':"TTS",'setting':"Hello",'language':"en",'zp_volume':"30"})
When I execute, I get the following:
  Sonos Error                     plugin does not have a <CallbackMethod> specified for action id actionZP_announcementMP3
  Script Error                    embedded script: IllegalParameterError -- plugin does not have a <CallbackMethod> specified for action id actionZP_announcementMP3
     embedded script, line 3, at top level
ValueError: IllegalParameterError -- plugin does not have a <CallbackMethod> specified for action id actionZP_announcementMP3
Any ideas?
Terry
Tue Dec 30, 2014 1:10 pm
Re: Sonos speech
What does the Actions.xml look like for actionZP_announcementMP3? Or maybe that is the problem – you have to define an action in the Actions.xml then that specifies the python callback that gets called.
Tue Dec 30, 2014 1:44 pm
nlagaros offline
Re: Sonos speech
You are brilliant! I actually had a typo in the Action id in the Actions.xml file. Made a quick change and it is working as expected. This will be out in the next release.
Thanks Matt!
