- Posted on
Sun Dec 21, 2014 8:45 am
pocster
offline
Hmmm,
Seems to work kind of now. Volume is very low (even though Level is set to 100). Also any music doesn't resume after the speech (or do I need to set that up manually some how? ; like a trigger?)
So!; it seems I just need to be able to generate progmatically a string .....
Though some errors now!
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 159, in actionZP_announcement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 954, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 940, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 307, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 860, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 732, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 699, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 683, in connect
<class 'socket.timeout'>: timed out
