'Address already in use' error with latest 0.8.1 release
Wed Nov 26, 2014 3:51 pm
colinpartridge offline
Have just updated to latest release and am getting the following the log..
Starting plugin "Sonos 0.8.1" (pid 53455)
  Sonos                           Subscribing on port: 9999
  Sonos Error                     Error in plugin execution InitializeMain:
  File "plugin.py", line 19, in __init__
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 127, in __init__
  File "<string>", line 1, in bind
<class 'socket.error'>: (48, 'Address already in use')
  Stopping plugin "Sonos 0.8.1" (pid 53455)
any ideas, was working fine before upgrade. OS version is 10.8.5 previous version was v0.6.20
Colin
Wed Nov 26, 2014 5:24 pm
nlagaros offline
Re: 'Address already in use' error with latest 0.8.1 release
Strange that you are getting this error on 0.8.1. I have it configured for socket reuse. Does it eventually startup after 20-30 seconds?
Colin
Wed Nov 26, 2014 5:30 pm
nlagaros offline
Can you resave the plugin configuration and also select a ZonePlayer type for each device you have configured. If you were on v0.6.20, several things have changed since then. Thanks.
Thu Nov 27, 2014 2:29 am
I have downgraded back to 0.6.2 and then upgraded to 0.7.1 without problem. checked that the devices had a zoneplayer type and then upgraded to 0.8.0. Its still not loading correctly but seems to be getting closer...
Enabling plugin "Sonos 0.8.0"
  Starting plugin "Sonos 0.8.0" (pid 54585)
  Sonos                           Sonos Ignition... [7]
  Sonos                           Sonos Ignition... [6]
  Sonos                           Sonos Ignition... [5]
  Sonos                           Sonos Ignition... [4]
  Sonos                           Sonos Ignition... [3]
  Sonos                           Sonos Ignition... [2]
  Sonos                           Sonos Ignition... [1]
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 122, in __init__
  Stopping plugin "Sonos 0.8.0" (pid 54585)
  Stopped plugin "Sonos 0.8.0"
if I now upgrade to 0.8.1 I get the same result as before...
Thu Nov 27, 2014 3:15 am
DomoPat offline
I had the same error 'address already in use' after upgrading from 0.7.1 to 0.8.1.
After an Indigo server stop and start the error disappeared...
Patrick
Thu Nov 27, 2014 7:55 am
[Solved}Re: 'Address already in use' error with latest 0.8.1
....and relax. Tried restarting Indigo server which didn't help so restarted the mac mini Indigo resides on and all appears to be working correctly. Cheers Nick and Patrick.
Colin
