just attempted a "reload" of the plug-in, perhaps helpful info to an expert?????
thanks so much for anyone willing to help
Nov 5, 2014, 4:21:46 PM
Reloading plugin "Sonos 0.5.11"
Stopping plugin "Sonos 0.5.11" (pid 1879)
Received INSTEON "Bedroom Lamp TV" on
Stopped plugin "Sonos 0.5.11"
Starting plugin "Sonos 0.5.11" (pid 9557)
Started plugin "Sonos 0.5.11"
Sonos Saved Plugin Configuration
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 53, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 89, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1087, in getPlaylistsDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 176, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 856, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 728, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 695, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 679, in connect
<class 'socket.error'>: (61, 'Connection refused')
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
