Nick, I'm having problems with the GA function. Running Mavericks and the latest plugin (just installed 2 weeks ago). I get the error below in my log, but I'm unsure of the workflow that I need to use to make this work in the first place.
I have a dedicated Mac Mini running Indigo 6. I have a line out into a Sonos CONNECT.
I've tried just doing a GA on my playbar, nothing.
Tried setting line in to the connect and then doing GA on the playbar and nothing. Both result in the error below. Any help is greatly appreciated. I'm sure I'm doing something wrong so I apologize in advance.
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 132, in actionZP_LineIn
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 711, in actionDirect
<type 'exceptions.TypeError'>: int() argument must be a string or a number, not 'NoneType'
File "plugin.py", line 159, in actionZP_announcement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 889, in actionAnnouncement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 875, in actionStates
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 270, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/socket.py", line 304, in read
<class 'socket.error'>: (54, 'Connection reset by peer')
Thanks for your time, contributions and help!
