Long batch of plugin errors...any ideas or don't mind it?
Posted: Sat Oct 06, 2018 12:42 am
Hmm...
I've been seeing in my logs for reasons I'm failing to grasp a big blurb of errors that I'm guessing relate to reaching out to an update server to find out if there's a new plugin version? Also It seems at the same time I have one recently installed LIFX mini bulb that in spite of happily being set up and controllable in the LIFX app, is having a devil of a time being "discovered" successfully by the plug-in. Any ideas?
Any help or pointers much appreciated! These are the lines of errors from the logs:
File "plugin.py", line 426, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/LIFX.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
LIFX Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
LIFX Error Discovery failed to complete for LIFX Device 'Kids Table R' [d0:73:d5:31:91:d4]
