gtreece wrote:Thanks for testing the fixAwesome, I appreciate it!
rekmira wrote:I was just wondering whether you had had the time to have a look at the plugging working with the Color 1000 globes? ...
rekmira wrote:OK - It looks like it should work - what we need to workout is why it isn't working for you.ok thanks
I guess its not the network then
rekmira wrote:Hi - good news![]()
After checking the VLAN settings on the router for the 192.168.7.x subnet I was able to add 2 lines which allows the Indigo server - and the plugin - to be able to communicate with the lamps.
rekmira wrote:Autolog - Since you bought the Color 1000 lamp for support, is there any way I can make a donation/contribute to the cost?
rekmira wrote:There is one more thing and it doesn't seem to be causing a problem but the debug log is showing some 'unknown type' and 'ignoring message' entries
[SNIP]
I don't know whether anyone else with Color 1000 lamps receives these? and it all seems to work anyway
so I just thought I would pass them on for your info
Using undocumented message types or field values, sending poorly formed messages or excessive message rates to LIFX devices and/or LIFX services may result in unexpected device or protocol message behavior.
