Re: Autolog LIFX Controller Discussion
Posted: Mon Jun 19, 2017 5:31 pm
Sounds awesome. Can’t wait to try it out after I get back from holiday
Software Support and Home Automation Forum
https://forums.indigodomo.com/
geoffosler1 wrote:First - love the plugin! Thanks very much for making this happen.
Sadly however, despite having upgraded to the most recent version, my LIFX devices keep disappearing from Indigo. Currently running Indigo 7.0.3 and Autologic v4.1.0
When I disable and reload the plugin, devices will be available and work fine for between 1-5 minutes, after which they'll switch to 'no ack' and stay that way until I reload the plugin.
I have tried factory resetting one of the devices and re-adding it to Indigo, but no luck; same thing.
I'm running 5 A19s, 4 BR30s, 1 Color 1000 and 1 Z LED strip all of which are running the latest firmware (which caused the problem to begin with)
Any advice?
geoffosler1 wrote:Tried resetting polling to 5 minutes, but this seemed just to delay the lamps switching to 'no ack' by, well, five minutes.
geoffosler1 wrote:Thanks again for working on this - also, I feel work of this quality should be at least acknowledged somehow... it's great stuff. Do you have a tip jar or something on Github?
geoffosler1 wrote:Well, it's been about 5 hours since I installed v4.1.3 and so far, so good! All lamps are online and none have dropped off.
I'll keep you posted if anything changes - and thanks again for all your help!
