Plugin install - action step
Fri May 01, 2015 2:46 pm
chrisla23 offline
I am trying to make the action group as mentioned in the install instructions. It did not create the Squeezebox folder or action to be modified as mentioned in the install.
Also when I manually create it, I don't have the process command action in the menu.
Please see attached.
How do I proceed with setup?
-Chris
Screen shot 2015-05-01 at 1.46.00 PM.png (336.07 KiB) Viewed 2208 times
Fri May 01, 2015 3:01 pm
Re: Plugin install - action step
Hi Chris,
You are installing version V2.0.n but looking at the instructions for an old version - I think maybe I should remove them :wink:
The instructions you want are these: Squeezebox Controller (V2.0.4) Information
You don't need to set-up the trigger in the new version.
Post back if you need further help. :)
Sat Nov 28, 2015 8:19 am
pocster offline
Hi!
I'm having some issues installing the plugin also.
Latest version.
My firewall is off but get:
Started plugin "Autolog Squeezebox 2.0.4"
Autolog Squeezebox METHOD TRACE: startup
Autolog Squeezebox Autolog 'Squeezebox Controller' initializing
Autolog Squeezebox Autolog 'Squeezebox Controller' initialization complete
Autolog Squeezebox METHOD TRACE: deviceStartComm
Autolog Squeezebox Initialising Communication Thread for 127.0.0.1:9090 []
Autolog Squeezebox Initialising Listen Thread for 127.0.0.1:9090 []
Autolog Squeezebox Started 'Squeezebox server': '127.0.0.1'
Autolog Squeezebox SELF.SERVERS for 'Squeezebox server' = {'status': 'starting', 'ipAddressPort': u'127.0.0.1:9090', 'lastScan': '?', 'playersMAC': '', 'keepThreadAlive': True, 'ipAddressPortName': u'127-0-0-1-9090', 'ipAddress': u'127.0.0.1', 'port': u'9090', 'datetimeStarted': datetime.datetime(2015, 11, 28, 14, 29, 34, 66000)}
Autolog Squeezebox METHOD TRACE: runConcurrentThread
Autolog Squeezebox METHOD TRACE [communicateWithServerThread]: run
Autolog Squeezebox ThreadSqueezeboxServer creating socket for : Host=[127.0.0.1], Port=[9090]
Autolog Squeezebox ThreadSqueezeboxServer Starting socket connect for : Host=[127.0.0.1], Port=[9090]
Autolog Squeezebox Error Communication Thread unable to start: 127.0.0.1:9090 [] [Reason = [Errno 61] Connection refused]
Autolog Squeezebox Communication Thread ended for 127.0.0.1:9090 []
Autolog Squeezebox METHOD TRACE [listenToServerThread]: run
Autolog Squeezebox listen Thread starting socket listen for 127.0.0.1:9090 []
Autolog Squeezebox Error Listen Thread unable to start: 127.0.0.1:9090 [] [Reason = [Errno 61] Connection refused]
Autolog Squeezebox Listen Thread ended for 127.0.0.1:9090 []
Sat Nov 28, 2015 10:23 am
It looks like for some reason the connection is being refused :(
Has it previously worked or are you trying it for the first time?
Does the Logitech Media Server web interface work i.e. url = 127.0.0.1:9000 ? from safari
Hopefully we can get this sorted :)
Sat Nov 28, 2015 10:45 am
pocster offline
Hey there!
Yeah first time install.
127.0.0.1:9000 from a browser fails also.
Appreciate your help.
Sat Nov 28, 2015 10:52 am
Ok - So that implies it isn't a plugin problem :)
Just double checking that you have installed and started the Logitech Media Server which the plugin needs to work?
Sat Nov 28, 2015 11:30 am
pocster offline
I rebooted yet again - it now works lol .
Thank you though for a brilliant plugin !
Sat Nov 28, 2015 11:34 am
Good news - glad it is working OK :)
