script for updating a google domain DDNS?
Tue Feb 27, 2018 9:18 am
Professor Falken offline
Does anyone have a script or another method for updating a Google Domain DDNS from within Indigo? (Not sure if a phrased that exactly right, but you probably get what I mean).
My router doesn't support updating Google's DDNS, but that's where I own the names, and they do have DDNS support. I know there are some separate client programs that do this, but configuring them seems to be a bear. Since I have the Online Sensor plugin, and it checks my public IP anyway, I figured one easy work around could be to just let Indigo take over this function via a device state change trigger.
Maybe I'm thinking about this wrong and there are reasons not to do it this way, but figured someone on the board may have doe this before.
Thanks.
Wed Feb 28, 2018 6:38 am
Re: script for updating a google domain DDNS?
https://support.google.com/domains/answ ... 3?hl=en-GB
There’s a simple HTTP call that can be made with a two or three line script.
Wed Feb 28, 2018 9:16 am
howartp wrote:
https://support.google.com/domains/answer/6147083?hl=en-GB
Yes, I saw that too, thanks. In fact, that's what made me think it would be scriptable within Indigo. The problem is, with my minuscule python abilities, I'm not exactly sure how to get my new IP (which will be a device state on the online checker plugin device) into the actual http call. Obviously substituting the domain and the generated credentials into their example call is easy, since that stuff doesn't change.
I also didn't really understand the second part of the description. It almost sounded like I needed to set up email on my domain, which I have no need for.
Note: You must set a user agent in your request as well. Web browsers will generally add this for you when testing via the above url. In any case, the final HTTP request sent to our servers should look something like this:
Example HTTP query:
POST /nic/update?hostname=subdomain.yourdomain.com&myip=1.2.3.4 HTTP/1.1
Host: domains.google.com
Authorisation: Basic base64-encoded-auth-string User-Agent: Chrome/41.0 your_email@yourdomain.com
If it was just something I was messing around with at home, I'd keep playing with it until I got it to work. But I'm a little concerned about doing that with google, lest I get locked out of my account or something for sending too many wrongly formatted calls.
Wed Feb 28, 2018 9:31 am
Colorado4Wheeler offline
It depends on which method you are using to make the call. Here is an example using the Online plugin's IP address state:
import requests
onlineDev = 12345 # Address of actual Online IP device
url = "http://{}".format(unicode(indigo.devices[onlineDev].states["ipAddress"]))
data = {"[]"} # Any JSON data you might be passing
data_json = json.dumps(data)
payload = {'json_payload': data_json}
r = requests.get(url, data=payload)
Wed Feb 28, 2018 11:05 am
Thanks. I'll see if I can run with that and make it work.
Wed Feb 28, 2018 11:11 am
If you copy and paste you'll get a missing JSON library, here's the corrected code:
import requests, json
Wed Feb 28, 2018 3:16 pm
Thanks again. I'm still trying to wrap my head around everything you've told me there and see where I'd need to put in my domain, username, and password.
However, I just noticed on a re-read of the Google Domains DDNS API, that if I just leave the myIP part of the call blank, the Google servers update the DNS record to the IP from which the call comes. Does that mean its as as simple as something like:
import requests
url = "https://username:password@domains.google.com/nic/update?hostname=subdomain.yourdomain.com>"
requests.get(url)
Can Indigo send https requests like that? My only experience was with http calls from one machine to another on my own LAN.
Wed Feb 28, 2018 3:22 pm
Sure, of course, I was just posting one that came to mind. There are probably at least a dozen ways to call a URL from Python, my simply including sending JSON if you needed to.
