Withings WS-50 Scale
Fri Nov 13, 2015 6:53 pm
pmgendon offline
Hey guys,
I'm trying to integrate my Withings WS-50 scale as a trigger for my morning routine in indigo. There is a IFTTT channel for the Withings, but I found that it is too slow to act as a trigger event.
Did anyone had success integrating the scale with indigo?
Many thanks
pm
Tue Dec 15, 2015 8:52 am
AndyVirus offline
Re: Withings WS-50 Scale
I use fingscan to check for active wifi connection and base the scene on that. Still slow (about 5 seconds or so depending how you configured fing) but does the job for me at the moment.
Sun Jan 03, 2016 7:29 pm
pmgendon offline
Thanks for the reply, I'll give it a look !!
many thanks :D :D :D
pmg
Thu Jan 07, 2016 9:13 am
Gusten offline
Hi
I have an follow up question.
If i use IFTTT to send me an mail when i wheigh myself
I there anyway to make Indigo change variable by automatic reeding the mail and set the variable as my weight ?
Or is it possible to use any other system to set an dynamic variable from "the internet" ?
I know its possible to trigger an event based on a matching word in the mail, but i was hoping i didnt have to make a trigger for every weight (85,1 kg, 85,2 kg, 85,3kg, 85,4kg...........). That would make 50-100 triggers and variables to set up.
(Withings have an API but i dont have the abillity to make an plugin)
/Martin
Thu Jan 07, 2016 9:39 am
I dont want to be reminded of my weight
Thu Jan 07, 2016 11:00 am
/Martin
What would you want from the API if someone turned it into a plugin?
Petet
Thu Jan 07, 2016 2:42 pm
Gusten offline
Just a simpel device per person that shows the latest messurment would be realy cool :)
Thu Jan 07, 2016 4:23 pm
The API itself is very easy to use, and the plugin would be very simple to knock up.
Unfortunately the authentication is not easy; either the author would need a public webserver that sits in-between the indigo user and the Withings server, and the author is granted secure access to each indigo users Withings data - or each indigo user would have to register for a dev account with Withings which is no mean feat itself.
I might have a look in a month or so, but I don't know if it's feasible even if I look.
If anyone else is interested, feel free to take it on.
Peter
Fri Jan 08, 2016 12:21 am
Gusten offline
Keeping my fingers croossed :mrgreen:
Sat Jun 24, 2017 9:58 am
evansgo offline
Hi all,
Did this ever go anywhere? I'd also be interested in this, the possibilities are endless from flashing lights to pre-recorded announcements like "get off me you're squashing me" etc etc :)
Sat Jun 24, 2017 10:52 am
Gusten offline
I did use httpd plugin and now i get my weight as a variable :)
Sat Jun 24, 2017 4:06 pm
Is that via IFTTT, using their Withings and URL recipes?
Sat Jun 24, 2017 10:07 pm
evansgo offline
I've not tried it, but I wondered if syncing it to fitbit (or similar) and then using the fitbit API may be easier?
Sat Jun 24, 2017 11:40 pm
Gusten offline
Yes, it's working nice, but have some delay
Sun Jun 25, 2017 12:18 am
evansgo offline
OK I set up a Fitbit account (you don't need a Fitbit) and it does seem to sync very quickly, all I need now is to learn how to get at the data :?
Is anyone else interested in this?
