Stopping Alexa playback
Sun Sep 12, 2021 4:48 pm
rustyhodge offline
I have a "Goodnight" action that stops all my media playing and turns off lights, etc. But if the Echo is playing something, I can't stop that.
Is there a simple way to get an Echo to stop playing?
I ran across this:
https://github.com/thorsten-gehrig/alex ... l_plain.sh
But it seems like it's log-in function can have issues with CAPTCHAs occasionally. I also don't want to have something logging into my Amazon account for this. (But an API key would be OK).
I don't want to have to put a Wave switch on the Echo just to stop it at night. Any commands I can send to it locally to get it to stop playing?
Mon Sep 13, 2021 9:34 am
Re: Stopping Alexa playback
Not that I know of, I didn't run across any API to do that (in fact, none that target echo devices directly).
Thu Mar 31, 2022 9:04 am
anyone offline
This is an old post, September 12th, 2021 but in that same month (8 days later), the author shared a way to generate a refresh_token, which avoids the CAPTCHA issues I believe you were referring to.
Basically the shell script logs into your Amazon account as you, from your local machine and performs the actions. On the authors blog he says; "the idea is to proxy the login to Amazon very similar to how a mobile app would". The blog is written in German but translates fairly well and explains how it works in more detail.
https://blog.loetzimmer.de/2021/09/alexa-remote-control-shell-script.html
The Alexa Remote Control Shell Script is what I use to allow Indigo to interact with my Alexa devices. I have had no issues using this solution. I can get Actions Groups and Triggers to generate speech on any Alexa device and get Indigo to ask an Alexa anything, as if I verbally asked it.
Back to your issue, I'd just code;
alexa_remote_control.sh -d 'Loft Echo' -e textcommand:'stop'
Which is the equivalent of saying; "Alexa, stop" to my Loft Echo Dot.
The only challenge I ran into implementing this solution was loading HomeBrew and JQ, during the initial setup. Just something I hadn't done before...not difficult.
Mon Apr 25, 2022 12:42 pm
rustyhodge offline
That is a very useful solution. Thanks for posting.
