How do I speak a variable
Mon Jan 15, 2018 7:01 am
MarcoGT offline
Hi all,
I am trying to let Indigo (v7) speak a variable.
I thought that using %%v:ID%% worked, but it doesn't. I am using the standard "speak" field in the Indigo GUI. I would like to avoid python because the action shall be maintainable by my father :D
Mon Jan 15, 2018 7:46 am
Re: How do I speak a variable
I don't believe that the Speak field in the Indigo UI supports substitutions.
Mon Jan 15, 2018 9:15 am
Colorado4Wheeler offline
I've built a speak utility into one of my plugins, it is currently for Airfoil setups but could pretty easily be modified to give you flexibility like being able to use whatever the system output is and being able to use variables. Just let me know what you need out of it entirely and I'll see what I can do (if you want to go down that route).
Mon Jan 15, 2018 10:21 am
MarcoGT offline
Ideally I would need a plugin where you can mix a combination of sentences + variables to be spoken, for example:
"The outside temperature is" + var_1 + "degrees with humidity of + "var_2" % + "Max temp will be " + var_3 + "and min temp will be" + var_4.
Something like this :)
Mon Jan 15, 2018 10:31 am
My Announcements plugin does precisely this. It’s in the plugin store. It’s still in beta, but works well as it sits.
Mon Jan 15, 2018 10:36 am
I would just go with Dave's plugin :wink:, it's already there and working.
Last edited by Colorado4Wheeler on Mon Jan 15, 2018 11:28 am, edited 1 time in total.
Mon Jan 15, 2018 10:58 am
MarcoGT offline
I only find the Announcer plugin by nsheldon, but not your Announcement plugin
Try the GIT link for it if you can't find it.
Mon Jan 15, 2018 11:31 am
MarcoGT offline
Yes, I got it from Git.
I created a new announcement device, but then I can I create a schedule to speak that announcement?
Mon Jan 15, 2018 11:40 am
I'm not sure if his are callable or not, I know they are devices but the only action I know of is to refresh the announcements. If you want to try mine out you can get it from my Git repository and it's an action rather than a device so it can be called on the fly.
Mon Jan 15, 2018 12:57 pm
MarcoGT offline
Your solution works fine, thanks a lot.
Thanks also to Dave for the support.
Mon Jan 15, 2018 2:28 pm
Yes, my plugin is system output agnostic. It's just for constructing the announcements themselves.
I'll take care of getting it up on the store (thought I had done that).
Tue Jan 16, 2018 10:41 am
ckeyes888 offline
Speaking of speaking variables...can that be done with a Python script?
Carl
Tue Jan 16, 2018 11:09 am
Yes it can:
indigo.server.speak("Hello world", waitUntilDone=True)
