I picked up a CAI WebControl 8 module to use for collecting data from door sensors (dry contact).
Seems like a great little ethernet connected IO module with tons of capability, and it seems relatively easy to poll using http.
This will allow me to integrate the existing door sensors into my Indigo-based home security system.
I saw while browsing the forums that another user or two may be using one of these.
For anyone who has one of these, what method are you using to collect data: simple scheduled poll with http, GhostXML, etc.?
The concern I have with simple polling is that the update interval would need to be relatively short in order for the system to be responsive to intrusion.
There is already processing delay for Indigo to trigger and perform and action, such as turning on a siren, so adding a large polling delay will just make the lag worse.
The ideal case would be to program the WebControl module to push IO state changes to the Indogo server.
However, this will be more of a challenge from a software perspective.
Thanks in advance.
jeff
