[ANSWERED]Does Anyone Have a Way to Monitor the Mac's UPS?
Sun Aug 07, 2016 3:01 pm
Swancoat offline
First off, apologies if this post is in the wrong place - I have no idea where to put it.
Anyway, the question is relatively straightforward, I'd like to monitor the UPS status of the Mac and fire triggers accordingly.
More specifics:
I have an APC UPS that my Indigo Mac runs on. You can connect it to the Mac via USB and through what I assume is some sort of standardized interface, there are some options in the Energy Saver control panel that it can control (i.e. if running on battery, put Mac to sleep in X minutes or whatever).
We often get small power dips here which trigger the UPS for a few seconds. This is all fine, my Mac keeps running and so does Indigo. However: I have a lot of plugins that start to behave badly and throw errors when the devices they control reboot. Reloading the plugins solves this.
So what I want to do is just have a trigger for when the UPS activates and goes back to line power, so I can wait a minute or so and then run some actions that reload my plugins.
SO: Any ideas on how to have a trigger pick up that Mac event? Is there some sort of Applescript method I can use or something?
Appreciate any help!
http://nerdhome.jimdo.com
Sun Aug 07, 2016 3:24 pm
Re: Does Anyone Have a Way to Monitor the Mac's UPS Status?
There is a plugin already -- the apcupsd plugin -- but the current version has a bug. It requires you to install the apcupsd daemon. I haven't seen a fix for the plugin's bug and haven't taken the time to try to find a cure (although I should.)
I agree that monitoring UPS would be a very useful thing.
Sun Aug 07, 2016 4:11 pm
FlyingDiver online
There's also bschollnick's plugin: viewtopic.php?f=33&t=8804
Sun Aug 07, 2016 7:09 pm
Swancoat offline
Oh snap. I swear I looked at the plugin list, but didn't see either of these. I should be set - thanks!
Sun Aug 07, 2016 9:37 pm
[MODERATOR NOTE] moved to a more appropriate forum.
Mon Aug 08, 2016 3:46 am
Yes you should. Lazy sod. :P
Mon Aug 08, 2016 4:09 am
Pardon? I was busy napping. :D
Mon Aug 08, 2016 7:05 am
Re: [ANSWERED]Does Anyone Have a Way to Monitor the Mac's UP
I'll have you know napping is my forte!
Tue Aug 09, 2016 12:28 pm
rehafer offline
This is timely. I just bought a small UPS to smooth the transition when my generator kicks on. Having some devices turn off during grid failure would help take the load off the generator. Not everything is on the generator circuit so restarts would be good too.
