Hello everyone,
New to Indigo (moving from an ISY).
I'm a bit overwhelmed. I wish there were documentation for walking thru creating a plugin for a sample device. I have no experience with Python, however, if I could get some of you to walk me thru the process from end to end - then I can apply that to other things I'd like to do. I'm hoping that asking for help in thsi way its not too offputting - it's how I learn.
I have this device (several), Its a ControlByWeb Relay X-310 (http://www.controlbyweb.com/x310/). It's a 4 in 4 out relay that can be accessed thru a web interface. It also can be controlled by issuing HTTP GET requests for control or query status.
I want to be able to turn each output relay (1-4) into virtual devices so they can be mapped to a KPL or just accessed thru the WEB INTERFACE. So I need to be able to issue commands to change states (on or off) - and also be able to query the device's state.
Inputs should also be able to be queried as well (in my case, some will be temperature (1-wire) and some will be digital input).
I can successfully issue commands using cURL in the terminal and see the response. But that is as far as I can go.
I'm not sure if this should be a plugin per se or just a series of scripts. As I said, I'm totally lost as to how to do this successfully in Indigo. (I did have this working in the ISY but in an extremely limited fashion: I can issue a HTTP Get request to change a relays state but cannot query the device to parse the value back in the ISY.... it's sort of a one-way interface... command goes out and thats it).
Also, there is a way to configure the device to push out changes to an external server submitting an XML file based on state change.
Thank you ahead of time for your consideration. If someone wants to teach me the process, it would be a big help in my wrapping my head around this.
