roussell wrote:I had the same thing happen years ago. I gutted the original controls from the box, took a spare Insteon dimmer (using it as a relay) and a spare 3 pole 120v coil relay from the parts bucket to automate my pool. Both legs of the 240v pump power are switched through the relay and one leg of the 240v is used to power the switch which energizes the coil of the relay. It's been working perfectly for over 3 years now and was essentially free since I already the parts lying around.
Thank you for that. That is what I ended up doing. I happened to have two extra Insteon dual-band dimmer switches. I did have to buy two contactors and found what I needed on Amazon for not a lot of money. (I got two 3PST DIN-mount contactors for about $20 ea., way cheaper than even one replacement mechanical timer.) I used the third pole of the pump motor contactor to provide an AND function to prevent the sweep from running if the main pump is not running. (That is the way the timers were wired too so it seemed prudent.) Everything works perfectly ... well, almost perfectly.
The problem I now have is that the Insteon communications is about 70%. The switches come on or go off only about 7 times out of 10 when activated by Indigo. Having the Insteon dimmer-switches in a metal box on the outside of the building, with a masonry wall between the box and the PowerLinc 2413U, suggests that radio control is unlikely. So I am likely limited to power line control.
I have a couple of BoosterLinc devices positioned on circuits very near my breaker panels. I have a signal bridge between legs of the 220 feed. I have tried connecting my switches to both legs of the 220V input in the pool pump control box to see of one works better than the other. There appears to be no difference.
So, is there a way to increase the reliability by getting Indigo to send an on or off command multiple times until it gets a clear ACK for the command?
