Guidance please - two motion sensors controlling one light
Sun Nov 01, 2015 9:14 pm
Pdoc offline
Hi I currently have one insteon motion detector in our driveway to turn on the front lights when we get home, (hights controlled by an instteon micro controller). However when we leave the house the front light doesn’t come on until you get to the drive way some 5-6 meters away so I was going to add another sensor near the front door.
What is the best way to configure this for smooth operation :D
Cheers
pete
Cheers,
Pete
Mon Nov 02, 2015 12:31 pm
Re: Guidance please - two motion sensors controlling one lig
It depends on what you have in terms of triggering available when you leave. If you're garage door is automated in any way you could turn on the lights that way for instance.
[MODERATOR NOTE] moved to a more appropriate forum.
Mon Nov 02, 2015 5:49 pm
Pdoc offline
Thanks Jay
The garage door is too far away from the front door, so I need the PIR facing down the driveway for when returning at night and a sensor at the front door for when leaving. Actually I have a spare magnetic open/close sensor I could attached that to the security door and when opened turns the lights on but how is it best to set up the commands so the sensor and RF open/close work together so one does not override the other etc. currently the driveway sensor leaves the lights on for 10 minutes after movement.
any guidance is appreciated
cheers
Pete
Cheers,
Pete
Mon Nov 02, 2015 6:27 pm
I don't think they need any real cooperation, right? If one goes off, start a 10 minute delayed off command. Even if both fire, the light will eventually go off.
