I bring up this thread as I have installed the Danfoss LC-13 radiator valve on one radiator.
Configured in Indigo, everything fine.
Now the setup is:
- boiler having still the original thermostat which schedules and so on.
- all radiators, except one, still have no controlling valves, so they are always open and water flows (when sent by the boiler)
- one radiator has the LC-13 installed
(let's suppose of course that the boiler is always sending water or that is sending when needed, I am not interested in boiler setup now).
A typical scenario would be: at 5pm I would like that the room temp is 20 grades...and here the first problem...how long does it take to bring room temp to 20C? If at 5PM I want it at 20, I shall start at 3PM (example); but let's say, to make it simpler, that at 5PM it will start to heat up to 20C.
So I have two variables, a desiredRoomTemp=20 (it will be set by the schedule) and the currentRoomTemp=17 read with a Fibaro sensor.
So current < desired, valve will open and radiator will heat up.
Then I need a schedule running for example every minute which checkes both temps and will close the valve accordingly, am I right?
I need some hints
Marco
