- Code: Select all
Airfoil Debug runConcurrentThread: update()
Airfoil Debug update method called
Airfoil Debug update: Airfoil is running
Airfoil Debug update: application sources: [app(u'/Applications/Airfoil.app').application_sources.ID(0), app(u'/Applications/Airfoil.app').application_sources.ID(1), app(u'/Applications/Airfoil.app').application_sources.ID(2), app(u'/Applications/Airfoil.app').application_sources.ID(3), app(u'/Applications/Airfoil.app').application_sources.ID(4), app(u'/Applications/Airfoil.app').application_sources.ID(7)]
Airfoil Debug update: device sources: [app(u'/Applications/Airfoil.app').device_sources.ID(5), app(u'/Applications/Airfoil.app').device_sources.ID(10)]
Airfoil Debug update: system sources: [app(u'/Applications/Airfoil.app').system_sources.ID(6)]
Airfoil Debug Current Source: app(u'/Applications/Airfoil.app').application_sources.ID(7)
Airfoil Debug update: speakers: [app(u'/Applications/Airfoil.app').speakers.ID(u'com.rogueamoeba.airfoil.LocalSpeaker'), app(u'/Applications/Airfoil.app').speakers.ID(u'28CFE981147F@Krithe AirPort Express'), app(u'/Applications/Airfoil.app').speakers.ID(u'A82066124310@mini'), app(u'/Applications/Airfoil.app').speakers.ID(u'ACBC3270262E@Apple TV'), app(u'/Applications/Airfoil.app').speakers.ID(u'00-1d-df-6f-c0-05:output')]
Airfoil Debug update: Computer (com.rogueamoeba.airfoil.LocalSpeaker) - Connected: 1
Airfoil Debug update: adding to newKnownSpeakers for id: ID-com.rogueamoeba.airfoil.LocalSpeaker value: (u'Computer', u'connected')
Airfoil Debug update: Krithe AirPort Express (28CFE981147F@Krithe AirPort Express) - Connected: 1
Airfoil Debug update: adding to newKnownSpeakers for id: ID-28CFE981147F value: (u'Krithe AirPort Express', u'connected')
Airfoil Debug update: mini (A82066124310@mini) - Connected: 0
Airfoil Debug update: adding to newKnownSpeakers for id: ID-A82066124310 value: (u'mini', u'disconnected')
Airfoil Debug update: Apple TV (ACBC3270262E@Apple TV) - Connected: 1
Airfoil Debug update: adding to newKnownSpeakers for id: ID-ACBC3270262E value: (u'Apple TV', u'connected')
Airfoil Debug update: JBL Flip 2 (00-1d-df-6f-c0-05:output) - Connected: 0
Airfoil Debug update: adding to newKnownSpeakers for id: ID-00-1d-df-6f-c0-05:output value: (u'JBL Flip 2', u'disconnected')
Airfoil Error Update failed. Check to see if Airfoil is functioning correctly and that there is only a single copy of the application on your hard drive.
Airfoil Debug Update failed with exception:
File "plugin.py", line 513, in update
newKnownSpeakers[speakerId] = (speakerName, connStr)
ValueError: IllegalParameterError -- illegal XML tag name character
