Back home...shadows up
Thu Feb 05, 2015 2:24 pm
MarcoGT offline
Hi all,
I would like to find a smart way to move shadows up when I get home.
I use dings can to detect home presence and it works like a charm :)
Then I have a door sensor on the entrance door and a motion sensor pointing the door.
The easiest way would be "iPhone home --> shadows up" but of course would be nice to integrate the motion sensor and the door sensor too.
But iPhone connects to wifi even before I open the door so I cannot use as condition door and motion sensors as they are still off.
As can I get it?
Marco
Fri Feb 06, 2015 1:56 pm
Vangelis offline
Re: Back home...shadows up
If I understand the logic correctly wouldn't this work?
iPhone detected -> Set variable
Door Open / Motion sensor triggered -> is iPhone variable true? (As a condition) -> Shadows Up
However if might have misunderstood
Vangelis
Sat Feb 07, 2015 2:04 am
MarcoGT offline
Yes, but that could not be enough.
Let's suppose that iPhone goes down (low battery, wifi not working and so on), then it reconnects and Indigo sets variable to "true", then motion is detected, it brings then shadows up, and of course this is wrong.
Idea was to set a variable "justEntered=true" when the main door is open, check if iPhone is connected and get the last connection time, then make a difference between currentTime and lastConnectionTime. If this is less the 45s (for example), then move shadows up.
Problem is that Indigo does not provide "time difference" function, I have to do it manually :)
Marco
Wed Mar 04, 2015 3:01 pm
How about "just entered = time stamp ". Then in a script check if time now < just entered +45 secs ...
Thu Mar 05, 2015 12:51 am
MarcoGT offline
Now I changed the logic, I have a small tablet on the wall so I can set (via Indigo Touch/Control Page) the variable "atHome"
With smartphone detection is not so easy as the WiFi network can do down blablabla :)
Sat Mar 07, 2015 2:16 am
In reference to your "justEntered" reply, you could have Indigo do the time difference you refer to.
Have a trigger on iPhone connection that sets iPhoneJustConnected variable to True. Then have a delayed action with say 30 second delay that sets it back to False.
In your door trigger, you can now test iPhoneJustConnected.
