For those using Airfoil, I'm assuming that amongst others, you have a number of Airports as targets.
My question is, do you configure yours to extend the wifi, or just join it, or none (cable input only)?
My wireless cable router is in the study, downstairs at one corner of a square 4-up, 4-down house. My bedroom is upstairs in the diagonally opposite corner.
With only the router emitting wifi, you can't get wifi in most of the house, so I've wired one Airport Express to the bedroom. Wifi is now reasonable in most of the house, but could still be better.
However my iPhone struggles to swap to the better signal as I roam around the house.
Do you have one SSID that all your APs (inc Airports) broadcast and your mobile devices roam based on signal, or different SSIDs in different areas? Do you manually switch to better signal?
I've just put in two additional Airports which are JOINed to the wifi, but not EXTENDing - because my gut feeling is that extending will just add more mid-strength APs for the iPhone to try and keep hold of when there's a better signal nearer.
Thoughts?
(This may seem daft, but by day I'm an IT Network Manager with close to 2,000 tablet/phone devices on a wifi network covering around 8 buildings with seamless roaming across the entire site - but that's on industry grade wifi equipment designed to talk to itself and roam all day long - I just don't seem to have any success at home! )
Peter
