I'm using a v4 controller. The 'v4' at the end of the create of the Controller object tells it to use v4 rather than v3. I'll admit that took me a while to figure out!
When setting up a roaming network (where the Access Points are connected via ethernet) each AP should be using it's own channel to avoid interference with the other APs.
What version of it, though?
RogueProeliator wrote:When setting up a roaming network (where the Access Points are connected via ethernet) each AP should be using it's own channel to avoid interference with the other APs.
That is only true if you are relying on the client devices to controller their connected AP... when you setup a zero-handoff group they all must be set to the same channel and the AP hardware determines which AP the clients should connect with. This is what makes the magic happen - to the client device it is basically not having to re-scan for frequencies when it gets low on connection and thus the handoff is MUCH faster.
I actually did extensive tests before implementing these with the various methods to allow roaming of APs... including different SSIDs for full-on different networks, same SSID on two APs with different channels and a DD-WRT in an extension mode. Nothing worked seamlessly except the Ubiquiti solution.
Obviously, though, your devices in use, the layout of your house and APs, etc. all affect what the best solution is for each individual.
Just checked, 4.7.6. Interesting!
Is your controller on the same computer or a difference computer than your Indigo server where the script is running? Mine is running on a Linux (Debian) box separate, obviously, from Indigo.
What APs are you using? I have Unifi ACs and thought that ZHO was not even functional with these units? I am running 4.7.6 as well.
edwazere wrote:Don't know if you want to take this to another thread if I can help to narrow down what doesn't work?
Cheers,
Ed.
lalisingh wrote:As much as I use Ubiquity radios for long haul wireless links - love them - For routers and AP's I prefer Mikrotik.
CamCom wrote:It seems that all you need is QOS (quality of service) functionality in your router, and you may not need all the bells and whistles (and sometimes hassles of DDWRT). All ASUS router that run the ASUSWRT stock firmware have QOS controls and you can easily upgrade to ASUSWRT-merlin for even greater control.
I personally recommend the AC-68U which is relatively affordable and has plenty of power. If you're set on DDWRT, here's a good list of options to get you started: DDWRT and ASUSWRT compatible routers
Another perk of the ASUS family of routers is they are some of the most widely compatible with third party firmware and as far as I know they are all (or almost all) supported by DDWRT, ASUSWRT-Merlin and TomatoUSB
