Mutilroom mm wave presence sensor
Tue Apr 25, 2023 8:57 am
CliveS offline
Re: Mutilroom mm wave presence sensor
anyone wrote:
How do you use the Aqara FP2 with Indigo?
In the Aqara app you can setup regions and also have an Occupancy On/Off
These can then be sync'ed to Apple Home
Update Apple Home with regions
Then in Home you get the 3 regions and Occupancy for on/off triggers
Then setup the shortcuts to trigger
CliveS
Thu Dec 07, 2023 5:04 am
lpraml offline
hi!
this really sounds interresting - and apart from the last step/screenshot looks "easy" - could you elaborate about the thirs step and how to get that going a little bit, or point me to where i can read up on that?
kind regards,
lukas
Thu Dec 07, 2023 9:37 am
CliveS offline
To get more info on setting up the shortcut in Apple Home App then take a look at
https://wiki.indigodomo.com/doku.php?id=indigo_2022.2_documentation:shortcuts
Hope that helps
CliveS
