power supply for for insteon triggerlinc
Mon Oct 14, 2013 6:23 pm
please delete this entry
Tue Oct 15, 2013 11:19 pm
Re: power supply for for insteon triggerlinc
If you like to solder and don't want to replace batteries .. here a $2 solution for the triggerlinc using standard electronics components -- and it fits into the triggerlinc box.
Using an old USB power supply and an old USB 2 cable
1. cut the USB cable close to the smaller connector
2. find the cable in the USB cable that carries the +5V, normally the red one. The "-" is the shield
3. solder the components together as shown in the schematics and the picture
4. attach the USB +5V and shield to the circuit: solder the usb cable to the short red/black cables.
Ready to go, connect USB power supply.
-- measure the voltage first (at the center pin of the LM 317 against ground), before connecting to the triggerlinc is always a good idea. It should be ~1.57V that is ~ the voltage of a fresh battery
This could also be used with other power supplies from any source, e.g. the garage door system runs on 12V, alarm systems also have ~ 12 volts etc..
Naturally if the power is off the triggerlinc is off too.
the components:
The LM317 can be bought at amazon for $1 (10 for $10)
the rest of the components (resistors, capacitors) are $0.10 .. $0.50
R1 220Ohm
R2 56 Ohm
C1 10uF
C2 0.1uF
the LM 317 schematics:
http://diyaudioprojects.com/Technical/V ... Regulator/
the USB cable connected
photo 4.JPG (112.41 KiB) Viewed 3388 times
the picture of the components in the triggerlinc
photo 2.JPG (119.77 KiB) Viewed 3388 times
the schematics
