GE Caddx NX-8E
Thu Nov 16, 2017 6:57 pm
Re: GE Caddx NX-8E
I have mine almost finished. Need to enable the sending of status changes in the nx system. Polling works.
Will post a version in the next days
In order to get your working you need the interface board nx584.
Then enable it on the alarm panel.
Sun Nov 19, 2017 8:54 pm
Re: GE Caddx NX-8E
I have the serial version NX584E. Don't not like to use the IP version = just bought the new system last week.
In my world alarm systems should NOT be connected to the "ether net" (internet)
The serial ports works very well. Will post an updated version
You have access to all info of the alarm system and can set anything you like..
But it must be in the vicinity of your indigo mac .. through serial cable ( 10m ) ?
Sun Nov 19, 2017 9:54 pm
GE Caddx NX-8E
Yes I understand you can isolate the alarm system virtually. But I like to make it physically.
As for time. I believe you can set it from theme mac. And ntp would require internet access or you would need a local ntp server.
In my setup the mac is next to the alarm system. The comm is pretty simple. So guess a set up through serial-ip- aerial might work
The good thing is everyone has the choice to do what he/she believes is the best for them.
Sun Nov 19, 2017 10:40 pm
Re: GE Caddx NX-8E
have ordered
USRIOT USR-TCP232-T2 Tiny Serial Ethernet Converter Module Serial UART TTL to Ethernet TCPIP Module Support DHCP and DNS $15.94,
will check it out if it works.
Mon Nov 20, 2017 11:17 am
Re: GE Caddx NX-8E
This is a modified version from the original:
https://www.dropbox.com/s/dfe6ab0z6s2ne56/Caddx%20Security%20System-v-7.4.2.zip?dl=1
changes:
1. uses indigo 7 features i.e. bulk update of states
2. added error control around serial communication. went from 1/10 comm errors (i.e. when reading whole database) to 1/day (handles message too short = continue to read; received 1.5 package, continue to read, use 2. message) if read error persists re-try 6 times (has not failed yet)
3. changed zone device type to custom: state column shows read/green/grey for : tripped/ normal/ other
4. added states "lastTripped", "lastNormal" time stamp ==> you can see when the door last opened/closed
5. added "read all zones" action to update all zones at once
6. added "read all zones" to watchdog function
7. added support for other NX models, i.e. NX8v2 and other
8. added field to set the folder name for CADDX devices and variables in config
9. recycle 2 variables at reload (Caddx_receiveMessage / Caddx_sendingMessage) = delete and recreate to reduce the space in SQL history databases
10. fixed some smaller bugs
12. added -- readOnly comments to config, device edit screens to make it clearer which items can be changed
and all the credit should go to Ian, he did 99% of the work. This is just fine tuning
Fri Mar 02, 2018 6:46 am
outsidenwnc offline
Re: GE Caddx NX-8E
I have a NX-8V2, just ordered a 584 card and will be setting this up in the next week or 2 . - THANK YOU
Mon Oct 08, 2018 10:25 pm
Re: GE Caddx NX-8E
I guess do a sync very 5 minutes. If no answer it’s not connected.
Wed Oct 10, 2018 9:22 pm
Re: GE Caddx NX-8E
Ian,
which version are you using.. the original or my modified version?
Thu Oct 11, 2018 10:01 am
Re: GE Caddx NX-8E
Ian,
1. checking the connection: create a schedule/action request interface Config ... then check variable Caddx_securityState. That should do it
2. on # of zone. I do not see any limits (besides<999) in the plugin for # of zones. BUT I have only 8 zones, and no extension module, so I can not really test that
hope that helps.
Sat Oct 13, 2018 12:11 am
Re: GE Caddx NX-8E
Will check tomorrow.
Sat Oct 13, 2018 4:52 pm
Re: GE Caddx NX-8E
https://www.dropbox.com/s/n7znyi3hwnrai6q/Caddx%20Security%20System-v-7.4.3.zip?dl=1
modified: all device dialog boxes go now from 1-32 instead of 1-8. hope that is enough.
not tested As I only have 8 zones /partitions
we can go to any number you like thats an easy mod
Mon May 06, 2019 10:06 pm
Re: GE Caddx NX-8E
its easy to add event type 164,, but what should it show?
here the If event type... with a dded 164. copied 168
           if deventType == 138:
                eventDeviceDescription = self.messageLogDeviceAddressDict(dzoneUserDevice -1)
                logEventMessagePrint = u"log event %s:      Loss of Supervision (wireless): %s,  zone: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1), dpartitionNumber , timeLogEvent)
            if deventType == 139:
                logEventMessagePrint = u"log event %s:      Loss of Supervision RESTORED (wireless): %s,  zone: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1), dpartitionNumber , timeLogEvent)
            if deventType == 164:
                logEventMessagePrint = u"log event %s:      system DISARMED: %s,  address: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1), dpartitionNumber , timeLogEvent)
                if self.plugin.enableSpeakPrompts:
                    indigo.server.speak(sayDisarmed)
            elif deventType == 168:
            elif deventType == 169:
                logEventMessagePrint = u"log event %s:      system ARMED: %s,  address: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1), dpartitionNumber , timeLogEvent)
                    indigo.server.speak(sayArmed)
            elif deventType == 173:
                logEventMessagePrint = u"log event %s:      entering program mode: %s,  address: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1), dpartitionNumber , timeLogEvent)
                # update enter keypad program mode states in plugin perferences
                self.plugin.pluginPrefs[u"isKeypadProgramming"] = True
                self.plugin.pluginPrefs[u"panelStatus"] = "Program Mode (enter)  ** %s " % self.timestamp()
                variableID = "Caddx_panelStatus"
                panelStatusVariable = (u"Program Mode (enter)  ** %s " % self.timestamp())
                self.updateVariable(variableID, panelStatusVariable)
            elif deventType == 174:
                logEventMessagePrint = u"log event %s:        exiting program mode: %s,  address: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1),  dpartitionNumber , timeLogEvent)
                # update exit keypad program mode states in plugin perferences
                self.plugin.pluginPrefs[u"isKeypadProgramming"] = False
                self.plugin.pluginPrefs[u"panelStatus"] = "Program Mode (exit)  ** %s " % self.timestamp()
                panelStatusVariable = (u"Program Mode (exit)  ** %s " % self.timestamp())
            elif deventType == 245:
                logEventMessagePrint = u"log event %s:      registering module: %s,  address: %s,  partition: %s  ** %s" % (deventNumber, eventDeviceDescription, (dzoneUserDevice -1),  dpartitionNumber , timeLogEvent)
            elif deventType == 247:
                logEventMessagePrint = u"log event %s:      confirm alarm system time and date set: %s  ** %s" % (deventNumber, timeStamp, timeLogEvent)
                logEventMessagePrint = u"log event %s:      alarm event: (%s)  is out of range of event dictionary definitions byte 5: (device address %s),  byte 6: (partition %s)  ** %s" % (deventNumber, deventType, (dzoneUserDevice -1), dpartitionNumber, timeLogEvent)
                if self.plugin.alarmEventInfo or self.plugin.debug:
                    indigo.server.log(u"log event %s:      data dictionary: %s " % (deventNumber, dataDict))
need to change This:
what would you like to have? see the other conditions. eg
Tue May 07, 2019 9:28 pm
Re: GE Caddx NX-8E
no.. your choice what to show ... do with it..
Mon May 20, 2019 2:24 pm
bpamiri offline
Re: GE Caddx NX-8E
Hi folks,
I had my NX-8v2 upgraded to an NX-8E and am now ready to connect it to my Indigo Mac mini. My Mac is going to be housed in the same location as the panel so I can go straight serial from the panel to the Mac. Can anyone that has done this, send me an Amazon link to the cable that can be used to setup the communication from the NX-8E to the Mac.
-Peter
Tue Apr 07, 2020 3:30 pm
farberm offline
Re: GE Caddx NX-8E
Karl is this what you order to connect into the network?
https://www.amazon.com/USRIOT-USR-TCP23 ... B01GPMFXB2
If so what is the pinout for the serial cable to connect them to the board.
Also setting for network connection would be helpful.
Users browsing this forum: No registered users and 19 guests
