Okay thanks, I'll let you know when I start that project.
Larry
hamw wrote:I thought I had the latest version of the plugin, 1.04, but apparently I have 1.02. I looked at the website and it does not appear available for download?
TED 5000 Plugin Debug Updating device: TED 5000
TED 5000 Plugin Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 55, in runConcurrentThread
File "plugin.py", line 74, in update
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/socket.py", line 348, in read
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 542, in read
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/socket.py", line 377, in read
<class 'socket.timeout'>: timed out
TED 5000 Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
TED 5000 Plugin Debug Starting concurrent thread
TED 5000 Plugin Polling Interval: 5
TED 5000 Plugin Error Error getting ted5000 data: 10.0.1.41
Received INSTEON "Thermostat MBR" temperature changed to 76.0
Users browsing this forum: No registered users and 30 guests
