FluxLED / MagicHome plugin
Thu May 17, 2018 4:56 pm
ckeyes888 offline
Re: FluxLED / MagicHome plugin
Yes, it does a slow fade between all colors.
Be great if it is implemented on the controller and accessible.
Virtually every IR controlled LED strip I’ve ever seen does have a fade function.
edit: Just checked the Magic Home app and it does support a bunch of various effects including fades...even has a speed control.
Carl
Fri May 18, 2018 5:08 pm
ckeyes888 offline
Plugin stopped working today. Getting this error.
 Flux LED Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 35, in runConcurrentThread
  File "plugin.py", line 96, in updateStatus
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 518, in __init__
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 692, in update_state
IndexError: bytearray index out of range
   Flux LED Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
If you turn the light on/off from the app the device is updated in Indigo. Just can’t control it at all from Indigo.
Carl
Mon May 21, 2018 2:48 pm
ckeyes888 offline
Is the plugin working for anyone else?
Carl
Mon May 21, 2018 6:35 pm
Carl
I just tested mine and it's working as expected.
Mon May 21, 2018 7:21 pm
ckeyes888 offline
I assume you’re running v0.0.3?
Won’t work at all for me.
Carl
Mon May 21, 2018 11:08 pm
jh71283 offline
Mine are both ok too.
Do you know if there has been a firmware update or anything that could have altered the controllers?
Has the IP address of them changed?
Tue May 22, 2018 8:48 am
ELWOOD offline
Have had a few times when there was a power outage and the magic home LED controller stops working. Have to use the Magic Home app to reconfigure the
local ip address and reconnect the controller. Other than that the plugin has worked OK.
Would be nice to be able to use the plugin to activate the different "functions" and "music" features in the Magic Home app.
Tue May 22, 2018 11:44 am
ckeyes888 offline
I tried resetting it completely with no joy. Not sure how to change the IP address.
The thing is the plugin is updating it’s on/off state when controlled by the app
so can’t see it being an IP issue. I’m still seeing the error I posted above after a complete reset.
Frustrating it won’t work. I have a number of LED strips I’d love to use it on and ditch
the IR stuff.
Carl
Tue May 22, 2018 2:26 pm
noel1983 offline
I have set mine with IP reservations on my router, that gets around messing with the magichome app/device.
No issues so far over here.
Tue May 22, 2018 4:42 pm
ckeyes888 offline
I just tried a second new wifi unit with the same result...app can control but not Indigo.
I’m running Indigo 7.1.1 and 10..8.5 if that matters.
Very much appreciate any ideas what may be going on.
Carl
Thu May 24, 2018 8:41 am
editordz offline
I LOVE this plugin, thank you for creating and maintaining it!
My two feature requests would be:
- Ability to set RGB (or RGBW) values when the light is turned off, i.e. ability to turn light on directly to a specific color. Right now, I have to turn the light on, and then set its color.
- Ability to turn on/off the built-in effects (color cycling, etc)
Dan
Fri May 25, 2018 9:47 am
jh71283 offline
Thanks for your patience, guys!
v0.0.4 has now been published to the store.
This adds support for activating the preset patterns, and also ensures the light is on prior to setting RGB values.
Carl - I have also updated the LED control library I use, so it might be worth a shot to see if this corrects your communication problems?
Fri May 25, 2018 8:24 pm
ckeyes888 offline
Nuts...still no go for me. If fact this version isn't updating changes made in the app as 0.0.3 did.
Here is the error:
Something to do with the Python version I'm running?
Carl
Sat May 26, 2018 2:00 pm
ckeyes888 offline
Getting a somewhat different error today.
  File "plugin.py", line 33, in runConcurrentThread
  File "plugin.py", line 95, in updateStatus
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 648, in update_state
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 620, in query_state
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 598, in _determine_query_len
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/FluxLED.indigoPlugin/Contents/Server Plugin/flux_led/__main__.py", line 1017, in _send_msg
error: [Errno 32] Broken pipe
Carl
Wed May 30, 2018 11:33 am
editordz offline
Thank you so much for the update. We're moving in a few weeks, and I'm looking forward to using several of these throughout the house! If you have a beer fund of sorts, I'd love to contribute, this plugin is awesome!
