GreenSky MQTT Bridge Plugin (SmartThings Bridge)
Wed Oct 17, 2018 12:57 am
Asconasny offline
Re: GreenSky MQTT Bridge Plugin (SmartThings Bridge)
Hi.
Great idea. Node Red is a perfect add.
Would be nice if you could share an example flow i Node red
But i have a an issue, im not reciving any mqtt messages in to the plugin.. i see on the broker side it sends out messages.
When i add a sensor and have the same topic as the 1.01 v it does´nt recive any mqtt messages
regards
Asconasny
Thu Nov 01, 2018 7:18 am
Umtauscher offline
I also cannot seem to get it to work.
I updated to the 3.01 version of the Plugin a few days ago, but I only can use the "indigo-set-decice" node.
When I use the node red native "mqtt in node" I can get the topics and states from the broker, so they seem to be published ok.
When I use the "indigo mqtt node" I simply cannot get anything. (1.1.2 btw) It seems to me the node not subscribing to the proper topic.
Has anyone got this to work? From which setting should the "indigo mqtt node" get the proper base of the "superbridge pattern"?
Am I just to dumb or is there something missing?
TIA
Wilhelm
Thu Nov 01, 2018 7:48 am
rlust offline
Does anyone have this working on Nodered? If so please share a flow.
I have connected to the device, and send the ON command but no action.
Also connected to the mqtt flow but not seeing any activity in Node Red, but see activity on a MQTT client.
Thu Nov 01, 2018 8:33 am
rlust offline
OK So I figured out a flow that works!
Screen Shot 2018-11-01 at 10.26.21 AM.png (146.5 KiB) Viewed 1021 times
Screen Shot 2018-11-01 at 10.27.37 AM.png (107.92 KiB) Viewed 1021 times
Screen Shot 2018-11-01 at 10.28.36 AM.png (92.67 KiB) Viewed 1021 times
Thu Nov 01, 2018 8:39 am
Umtauscher offline
.. and do you get anything on the topmost input node for "family room cans"?
I suspect not.
Fri Nov 02, 2018 8:32 am
Umtauscher offline
Ok, let me try to make the question a little more specific:
As I understand it, the node type "indigo mqtt" is to define an input node that is supposed to react on messages from a specifig device, right?
There are 4 fields that define such a node:
MQTT Broker
Indigo Controller
ItemName
State
Anyways none of my nodes do anything when indigo publishes a new MQTT message.
From where does Node Red know, what superbridge patterns Indigo ha set?
What might I be doing wrong?
TIA
Wilhelm
Fri Nov 02, 2018 8:44 am
jh71283 offline
Hi Wilhelm!
The Indigo MQTT In node is basically a wrapper around a standard MQTT in node, to make it easier for us.
As long as you are running the GreenSky MQTT plugin > v3, it will publish some autodiscover information to a specific topic that allows the node red node to discover the superbridge patterns.
Only the Indigo MQTT In node is MQTT based, the others send commands direct to the Indigo Rest API.
I'm guessing if you don't have superbridge patterns set, the system will get a bit upset.
The defaults are:
SuperBridge Out
house/devices/{DeviceName}/{State}
SuperBridge In
house/devices/{DeviceName}/{State}/set
SuperBridge Action Groups
house/scenes/{ActionGroup}/execute
Fri Nov 02, 2018 8:46 am
jh71283 offline
BTW, the "State" is optional on the input node, it basically acts like a filter so that only updates to that state will make it through. If it's filled in, then it will also show the current value for that state on the NR UI.
Fri Nov 02, 2018 8:51 am
Umtauscher offline
Ok, thanks that basically is what I figured apart from the superbridge.
I have set the superbridge exactly as you are describing - nothing happens.
So I suppose Node Red is not subscribing to the correct topics, as I can see they are published.
How could I try to debug this?
Fri Nov 02, 2018 8:53 am
jh71283 offline
Feel free to post your flow on here and I'll take a look. Please be careful to remove your indigo password from the json beffore you post it though!
Fri Nov 02, 2018 8:54 am
jh71283 offline
Here is the example flow for my kitchen light control:
[{"id":"ab3cd17b.d0bf6","type":"switch","z":"df34ea84.df1908","name":"","property":"payload.newValue","propertyType":"msg","rules":[{"t":"eq","v":"True","vt":"str"},{"t":"eq","v":"False","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":336.25000762939453,"y":202.50000190734863,"wires":[["7db1a4bb.73537c","9f76fe5a.0da96"],[]]},{"id":"7db1a4bb.73537c","type":"trigger","z":"df34ea84.df1908","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"10","extend":true,"units":"min","reset":"","bytopic":"all","name":"","x":590,"y":200,"wires":[["9f76fe5a.0da96"]]},{"id":"7c26d8e.5429428","type":"switch","z":"df34ea84.df1908","name":"On/Off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","outputs":2,"x":552.5000076293945,"y":301.2500057220459,"wires":[["f96ac0d1.1b95d"],["30c5cf5.3b0333"]]},{"id":"30c5cf5.3b0333","type":"time-range-switch","z":"df34ea84.df1908","name":"","lat":"","lon":"","startTime":"goldenHour","endTime":"22:00","startOffset":"-60","endOffset":0,"x":761,"y":350,"wires":[["b93131e8.80f1"],["820f7582.8dde18"]]},{"id":"f96ac0d1.1b95d","type":"function","z":"df34ea84.df1908","name":"100%","func":"msg.payload = {brightness: 100}\nreturn msg;","outputs":1,"noerr":0,"x":1042,"y":271,"wires":[["6a152ec.b3580d"]]},{"id":"b93131e8.80f1","type":"function","z":"df34ea84.df1908","name":"30%","func":"msg.payload = {brightness: 30}\nreturn msg;","outputs":1,"noerr":0,"x":1042,"y":311,"wires":[["6a152ec.b3580d"]]},{"id":"820f7582.8dde18","type":"function","z":"df34ea84.df1908","name":"off","func":"msg.payload = {brightness:0}\nreturn msg;","outputs":1,"noerr":0,"x":1042,"y":351,"wires":[["6a152ec.b3580d"]]},{"id":"9f76fe5a.0da96","type":"switch","z":"df34ea84.df1908","name":"Check Auto Mode","property":"KitchenLightMode","propertyType":"global","rules":[{"t":"eq","v":"-1","vt":"num"}],"checkall":"true","outputs":1,"x":587.5000076293945,"y":241.25000381469727,"wires":[["7c26d8e.5429428"]]},{"id":"d22491e6.e3ccd","type":"ui_button","z":"df34ea84.df1908","name":"","group":"3a7f166.1baa8ea","order":0,"width":0,"height":0,"passthru":false,"label":"Off","color":"","bgcolor":"","icon":"","payload":"0","payloadType":"num","topic":"","x":430,"y":60,"wires":[["a9170169.7a406"]]},{"id":"a9a78dc0.8e18d","type":"ui_button","z":"df34ea84.df1908","name":"","group":"3a7f166.1baa8ea","order":0,"width":0,"height":0,"passthru":false,"label":"On","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"num","topic":"","x":430,"y":20,"wires":[["a9170169.7a406"]]},{"id":"df60b3c9.f554d","type":"ui_button","z":"df34ea84.df1908","name":"","group":"3a7f166.1baa8ea","order":0,"width":0,"height":0,"passthru":false,"label":"Auto","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"num","topic":"","x":430,"y":100,"wires":[["a9170169.7a406"]]},{"id":"a9170169.7a406","type":"function","z":"df34ea84.df1908","name":"Set Light Mode","func":"global.set(\"KitchenLightMode\", msg.payload)\nreturn msg;","outputs":1,"noerr":0,"x":640,"y":60,"wires":[["1082eaa7.8ddfb5"]]},{"id":"1082eaa7.8ddfb5","type":"switch","z":"df34ea84.df1908","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"-1","vt":"num"}],"checkall":"true","outputs":3,"x":860,"y":60,"wires":[["820f7582.8dde18","c61845f3.c68758"],["f96ac0d1.1b95d","1cf661b4.623f0e"],["b2f6ba79.8f07e8"]]},{"id":"a8375aa7.6d2328","type":"ui_text","z":"df34ea84.df1908","group":"3a7f166.1baa8ea","order":0,"width":0,"height":0,"name":"","label":"Current Mode","format":"{{msg.payload}}","layout":"row-spread","x":1180,"y":60,"wires":[]},{"id":"1cf661b4.623f0e","type":"change","z":"df34ea84.df1908","name":"On","rules":[{"t":"set","p":"payload","pt":"msg","to":"On","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":80,"wires":[["a8375aa7.6d2328"]]},{"id":"c61845f3.c68758","type":"change","z":"df34ea84.df1908","name":"Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"Off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":40,"wires":[["a8375aa7.6d2328"]]},{"id":"b2f6ba79.8f07e8","type":"change","z":"df34ea84.df1908","name":"Auto","rules":[{"t":"set","p":"payload","pt":"msg","to":"Auto","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":120,"wires":[["a8375aa7.6d2328"]]},{"id":"6a152ec.b3580d","type":"function","z":"df34ea84.df1908","name":"Extract Brightness","func":"msg.payload = msg.payload.brightness\nreturn msg;","outputs":1,"noerr":0,"x":1331,"y":291,"wires":[["b4f8ed72.6018a"]]},{"id":"88acb8a.b5e1a48","type":"link in","z":"df34ea84.df1908","name":"Hallway Movement Mornings","links":["cef292b4.d108f"],"x":465.5,"y":129,"wires":[["7db1a4bb.73537c"]]},{"id":"b4f8ed72.6018a","type":"indigo-set-device","z":"df34ea84.df1908","name":"","controller":"c34bc931.94bec8","itemname":"Kitchen Lights","key":"brightness","x":1610,"y":312,"wires":[[]]},{"id":"7542c362.6802cc","type":"indigo mqtt in","z":"df34ea84.df1908","name":"","topic":"","qos":"2","broker":"dd07ed2a.fe8fb","controller":"c34bc931.94bec8","itemname":"Kitchen Motion","state":"onOffState","x":89.375,"y":140,"wires":[["8fbd3e4f.c2cef","ab3cd17b.d0bf6"]]},{"id":"8fbd3e4f.c2cef","type":"debug","z":"df34ea84.df1908","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":278.125,"y":270,"wires":[]},{"id":"51a9e96b.a88798","type":"indigo mqtt in","z":"df34ea84.df1908","name":"","topic":"","qos":"2","broker":"dd07ed2a.fe8fb","controller":"c34bc931.94bec8","itemname":"Kitchen Door","state":"onOffState","x":80,"y":233.75,"wires":[["ab3cd17b.d0bf6"]]},{"id":"3a7f166.1baa8ea","type":"ui_group","z":"","name":"Kitchen Light Mode","tab":"bfc2574c.3acae8","disp":true,"width":"6","collapse":false},{"id":"c34bc931.94bec8","type":"indigo-controller","z":"","name":"Indigo","protocol":"http","host":"10.0.1.9","port":"8176","username":"john","password”:”XXX”},{“id":"dd07ed2a.fe8fb","type":"mqtt-broker","z":"","broker":"10.0.0.5","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"15","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"bfc2574c.3acae8","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
Fri Nov 02, 2018 9:05 am
Umtauscher offline
I don't knopw why, but I cannot paste your flow into my Node Red tab.
So here is the simplest I can think of from mine
Fri Nov 02, 2018 9:16 am
jh71283 offline
You just re-posted my flow :D
Fri Nov 02, 2018 9:26 am
Umtauscher offline
Dooh, sorry,
[{"id":"36a3df0.ee80022","type":"debug","z":"191b5c63.0c9264","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":590,"y":1120,"wires":[]},{"id":"bc5c15b6.a66e7","type":"indigo mqtt in","z":"191b5c63.0c9264","name":"","topic":"","qos":"2","broker":"8871a16b.8e731","controller":"2b8f6f57.a868b8","itemname":"Schreibtischlampe","state":"","x":310,"y":1120,"wires":[["36a3df0.ee80022"]]},{"id":"8871a16b.8e731","type":"mqtt-broker","z":"","name":"IndigoBroker","broker":"mqttbroker.voyager95.de","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"2b8f6f57.a868b8","type":"indigo-controller","z":"","name":"Indigo.voyager95.de","protocol":"http","host":"indigo.voyager95.de","port":"8176","username":"username","password":"XXX"}]
I have to get used to using the export menue instead of simply copying to clipboard...
Fri Nov 02, 2018 9:34 am
jh71283 offline
Everything looks ok from what I can see.
Try this flow, I have just added a "All MQTT Messages" node to help debug.
[{"id":"ad0ebc40.21b4e","type":"debug","z":"c3da65c6.feffb8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":524,"y":156,"wires":[]},{"id":"10ba04d3.b5a99b","type":"indigo mqtt in","z":"c3da65c6.feffb8","name":"","topic":"","qos":"2","broker":"39e362d4.f9f6de","controller":"324d1e6.a9b81e2","itemname":"Schreibtischlampe","state":"","x":244,"y":156,"wires":[["ad0ebc40.21b4e"]]},{"id":"c81503cc.44be5","type":"mqtt in","z":"c3da65c6.feffb8","name":"All MQTT Messages","topic":"#","qos":"2","broker":"39e362d4.f9f6de","x":244.5,"y":200,"wires":[["ad0ebc40.21b4e"]]},{"id":"39e362d4.f9f6de","type":"mqtt-broker","z":"","name":"IndigoBroker","broker":"mqttbroker.voyager95.de","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"324d1e6.a9b81e2","type":"indigo-controller","z":"","name":"Indigo.voyager95.de","protocol":"http","host":"indigo.voyager95.de","port":"8176","username":"username","password":"XXX"}]
Page 6 of 10 1 ... 3, 4, 5, 6, 7, 8, 9, 10
