jay (support) wrote:HeyThat's really odd that it ever worked: the variable_url_redirect plugin doesn't support authentication before the hostname (as mentioned in the very first post on this topic)...
matt (support) wrote:This isn’t possible then as a variable ????? ( though it did work )Instead of having SS upload an image, I'd suggest just directly accessing SS's built-in Web server. An example URL that you would stuff into the variable value would look like:
- Code: Select all
http://ss_username:ss_password@192.168.0.4:8000/++image?cameraNum=1&width=320&height=240
(assuming you have authentication enabled on SS you can pass in the username/password as shown above)
pocster wrote:The original post was about cycling ip camera images . So it can’t be done ??
pocster wrote:matt (support) wrote:This isn’t possible then as a variable ????? ( though it did work )Instead of having SS upload an image, I'd suggest just directly accessing SS's built-in Web server. An example URL that you would stuff into the variable value would look like:
- Code: Select all
NOAAicon = indigo.variables[1596524366].value
MyLink = '%s%s%s' % ("MyReflector.indigodomo.net/public/NOAA256/NOAA%20256%2B", NOAAicon, ".png")
indigo.variable.updateValue(1373139711, value=MyLink)
WebServer http://localhost:8176/variable_url_redirect/redirect?name=CurrentCam load error: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)>
http://USERNAME:PASSWORD@localhost:8176/variable_url_redirect/redirect?name=VARIABLENAME
