SVG Plugin
Fri Jul 07, 2017 7:44 pm
jblackburn offline
SVG Plugin
Hi everyone,
Today, I share one of my plugin. I've designed it for my own needs but it's can help others! Sometime I prefer to represent some data in graphic dials instead of text/numbers. In some cases, heuristic images can do the job but in certain situation, you need a more sophisticated tool. It's why I've designed SVG plugin! Big advantage of SVG file, you can modify it with a text editor (XML)! SVG is based on this concept!
You'll find all information on my web site (basic page):
SVG Page
But at first, I strongly recommend starting with the help file:
SVG help file (pdf)
If you have any questions or comments, don't hesitate!
NOTE1: Thanks for my beta testers!
NOTE2: This is a beta release even if I've ran it for three months without major issues!
Joël
Fri Jul 07, 2017 8:04 pm
Re: SVG Plugin
Let me say that I have tried the SVG plugin and it is amazing. Very powerful and a great addition to the Indigo community!
Joël, I think you meant to say "NOTE2: This is a beta release even if I've ran it for three months without major issues!"
Congratulations on your Beta!
Fri Jul 07, 2017 9:33 pm
jblackburn offline
Re: SVG Plugin
Lol! Corrected! Thanks Dave! :D
Mon Jul 10, 2017 3:39 pm
Re: SVG Plugin
Thanks for the contribution!
Tue Jul 11, 2017 9:48 am
Re: SVG Plugin
This looks really neat, and your example control page image is very slick. As Jay said, thanks for the contribution!
Tue Jul 11, 2017 9:57 am
Re: SVG Plugin
Also, good job on the thorough documentation. We need to come up with some mechanism by which plugins can more automatically rasterize control page images.
Tue Jul 11, 2017 4:58 pm
Re: SVG Plugin
Here the formula used depend of value type
Docs bug on page 6.
Tue Jul 11, 2017 5:01 pm
Re: SVG Plugin
matt (support) wrote:
Also, good job on the thorough documentation. We need to come up with some mechanism by which plugins can more automatically [s]rasterize control page images[/s] generate their own documentation.
I agree!
Thu Jul 13, 2017 7:54 pm
jblackburn offline
Re: SVG Plugin
....and your example control page image is very slick. ....
Thanks! This is my current dashboard (with extended info.) displayed on a TV all day... :wink:
Joēl
Tue May 01, 2018 4:43 am
srkinard offline
Re: SVG Plugin
jblackburn wrote:
Hi everyone,
SVG Page
SVG help file (pdf)
Joël
This is very cool...a few questions tho...would it be possible to add a stroke function with 3 or 4 colors?
Like for battery gauges I'd like to have <10% as red, 10-20% as orange, 30-40% as yellow, and >40% as green.
Temp gauges would be even more complex...if possible...from dark blue at freezing to red at 100+ (F scale)
dark blue, blue, cyan, light green, green, yellow, orange, red, dark red
I really like the dials you have as an example...how would it need to be changed for the 0 to start at top...like 12 noon on a clock?
Ross
Wed May 02, 2018 6:32 pm
jblackburn offline
Re: SVG Plugin
You can add mutiple commands related to the same element. See my exemple below...
You can use multiple “Fill Color 1x” function in sequential:
Fill Color 1x. - 0 to 9 -> Red
Fill Color 1x. - 10 to 20 -> Orange
Fill Color 1x. - 21 to 40 -> Yellow
Fill Color 1x. - 41 to 100 -> green
Conditions are evaluated in order. The last condition is applied to the svg file
You can do the same as previously! Same for stoke command.
In my example, the “0” is located at 3 o’clock. In your SVG editor (e.g. Inkscape), rotate this element by -90 (or 270) to setup your “0” at 12 o’clock.
Note to myself: Add buttons to change command order (e.g. up & down)
Joel
Users browsing this forum: CliveS and 1 guest
