Monoprice 6 Zone Amp Plugin
Sun Nov 27, 2016 7:49 pm
kwijibo007 offline
Hi All,
I've written an Indigo 7 plugin to control Monoprice 6 Zone Amps (https://www.monoprice.com/product?p_id=10761).
Supported actions below:
    Turn On
    Turn Off
    Set Volume (directly sets the volume level)
    Increase Volume (increases volume by 1)
    Decrease Volume (decreases volume by 1)
    Set Balance (directly sets the balance level)
    Increase Balance (increases balance by 1)
    Decrease Balance (decreases balance by 1)
    Set Bass (directly sets the bass level)
    Increase Bass (increases bass by 1)
    Decrease Bass (decreases bass by 1)
    Set Treble (directly sets the treble level)
    Increase Treble (increases treble by 1)
    Decrease Treble (decreases treble by 1)
    Mute On
    Mute Off
    Set Source (directly sets the source)
    Toggle Source Fwd (moves to the next configured source)
    Toggle Source Rev (moves to the last configured source)
When I started writing the plugin I didn't realise that RogueProeliator's Dayton Audio plugin also supported the Monoprice units. :oops: RogueProeliator's plugin supports daisy chaining which this one doesn't. There are a couple of other differences so it may prove useful to some people...
Full instructions and the plugin download can be found here https://aushomeautomator.wordpress.com/monoprice-6-zone-amp-indigo-plugin/.
Would appreciate any feedback.
Pete
Thu Apr 06, 2017 12:52 pm
alphaboy offline
Re: Monoprice 6 Zone Amp Plugin
Great plug-in, tried it running off an Xserve (with built in Serial port) and worked perfectly... I do have 2x 6 zones with the master / slave cable so would love to adapt the plug-in to support 12 zones.
Also would love to know what would be involved in order to make this plug-in work on indigo version 6?
Thanks again and great work!
Thu Apr 06, 2017 1:33 pm
RogueProeliator's Dayton Audio plugin supports master/slave units and works on Indigo 6. Just FYI.
Thu Apr 06, 2017 10:43 pm
kwijibo007 offline
Thanks for the feedback, alphaboy :D
I'd like to add the master/slave capability at some stage. It's on my to-do list but as I only have one unit it's difficult to test. As FlyingDiver suggested though, RougueProeliator's plugin has both those capabilities.
Happy to try and accommodate any other feature requests if you have any..
Pete
Fri Feb 26, 2021 5:33 pm
haychess offline
Hi.
Ever since updating Indigo to 7.5, I am having issues with the Monoprice plugin. It keeps giving me this error over and over in the log:
Monoprice 6 Zone Amp Error More than 6 zones have been returned - Should not be possible??
I can't control the plugin any longer.
Do you know what's up with it?
