Verisure Plugin
Mon May 16, 2016 12:24 pm
Re: Verisure Plugin
Looks like you need to install pip2.6, try this:
sudo easy_install-2.6 pip
Mon May 16, 2016 12:56 pm
Bjornror offline
Re: Verisure Plugin
Thank You That solved all problems :)
Mon May 16, 2016 1:10 pm
Bjornror offline
Re: Verisure Plugin
Thanks for a great app :D
Fri Jun 17, 2016 5:18 am
haavarda offline
Re: Verisure Plugin
Have an error that is causing the plugin to dump a lot of errors in the log. Seams to be related to unicode?
Any idea?
Håvard
7. jun. 2016, 13.15.14
  Verisure Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 108, in runConcurrentThread
  File "plugin.py", line 191, in _refreshAlarmStatesFromVerisure
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe5' in position 1: ordinal not in range(128)
  Verisure Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  File "plugin.py", line 193, in _refreshAlarmStatesFromVerisure
Håvard
Fri Jun 17, 2016 5:26 am
lindehoff offline
Re: Verisure Plugin
Any idea?
Håvard
Sorry to hear that you are having problems with the plugin, I have some questions?
How often do it occurs?
Witch version of the plugin are you running?
Is debugging on or off?
Fri Jun 17, 2016 9:01 am
haavarda offline
Re: Verisure Plugin
It happens after some time, not right after the plugin is enabled. I have been busy so I have had it disabled for some time, but updated to latest version before posting.
I have not had debug active.
Thanks for your quick reply.
Håvard
Håvard
Fri Jun 17, 2016 9:07 am
haavarda offline
Re: Verisure Plugin
See time stamps below :)
Håvard
17. jun. 2016, 16.56.26
  Indigo Cocoa client authenticated (192.168.1.101)
  Enabling plugin "Verisure 0.3.2"
  Starting plugin "Verisure 0.3.2" (pid 56351)
  Started plugin "Verisure 0.3.2"
  Verisure Debug                  startup called
  Verisure Debug                  Debug is set to: False
  Verisure                        Checking for updates...
  Verisure                        No updates are available
17. jun. 2016, 16.58.08
  Action Group                    Verisure - enable AutoLock & Lock
  Verisure                        Updated autolock for 'Doorman' to True
  Schedule                        _delayed_action_58
  Verisure                        Updated Lock State: LOCKED
17. jun. 2016, 17.00.54
  Verisure                        Debuging is set to: True
  Verisure                        Debuging is set to: False
17. jun. 2016, 17.02.48
  Indigo Cocoa client connected
  Indigo Cocoa client disconnected
Håvard
Sat Jun 18, 2016 3:57 am
CrazyFin offline
Re: Verisure Plugin
First of all:
@lindehoff: GREAAAT plugin! :D I recently installed 2 of the Yale Doorman locks and it is so wonderful to be able to monitor their status in Indigo even though I currently only have the OLDER version of the Verisure alarm (which means that I needed to buy their smart plugin as well to be able to control the door locks remotely).
I had some trouble installing the latest version 3.2.2 until I realised that I first needed to download version 3.0.0 in order to get the plugin installation script (Verisure.indigoPlugin) that is the one to run to do the first initial install into Indigo. When I downloaded 3.2.2 it was just the source code which can not be used to install the plugin into Indigo.
After that I installed 3.0.0 first then it was easy to upgrade the plugin to 3.2.2 using the upgrade function in the plugin itself. :-)
Maybe you could update the installation description in the first post or add the installation script file to the 3.2.2 download post?
@haavard: I had the same issue as you but as soon as I changed my door lock names to not contain any of the Swedish characters ÅÖÄåäö then those errors disappeared for me.
This was the error I saw in the log until I renamed my door locks:
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in position 4: ordinal not in range(128)
I have Swedish characters åäöÅÄÖ in the device name in Indigo though and that works fine.
Sat Jun 18, 2016 4:29 am
haavarda offline
Re: Verisure Plugin
My doorman unit is called just doorman. But the lock status is displayed as "Låst"(locked). I can't change this as it is verisures state. Could the errors be related to this?
Håvard
Sat Jun 18, 2016 4:46 am
CrazyFin offline
Re: Verisure Plugin
Hmmm no I dont think that actually. In my Android app for the lock status is in English (on My Pages on Verisure's home page) and therefore displays just Locked or Unlocked.
However, when I use Chrome on my local computer to access the same pages I have the GUI in Swedish and displays "Låst" or "Upplåst".
My errors disappeared when I was manipulating the door name in the Verisure My Pages GUI. Could it be that you have some invisible characters AFTER "doorman" in the field for the door lock name in the Verisure My Pages?
Sat Jun 18, 2016 1:03 pm
haavarda offline
Re: Verisure Plugin
I tried deleting the device and recreating it. So far I have not seen the error again. So it have something to do with something I have done on the verisure pages. Thanks for a great plugin.
Håvard
Håvard
Mon Jun 20, 2016 1:01 am
lindehoff offline
Re: Verisure Plugin
Håvard
Good, if it occurs again, please contact me.
Sun Nov 13, 2016 1:41 pm
jens offline
Re: Verisure Plugin
Hello have upgrading to Indigo 7 and then the plugin dount work any more, please help :(
//Jens
Mon Nov 14, 2016 4:42 am
lindehoff offline
Re: Verisure Plugin
//Jens
I have tested the Verisure plugin against an beta of Indigo 7 and it work.
What errors do you get?
Mon Nov 14, 2016 12:42 pm
jens offline
Re: Verisure Plugin
This is what i get in the log
Loading plugin "Verisure 0.3.2"
Starting plugin "Verisure 0.3.2" (pid 26131)
Verisure Error Error in plugin execution InitializeMain:
File "plugin.py", line 12, in <module>
ImportError: No module named verisure
Stopping plugin "Verisure 0.3.2" (pid 26131)
//Jens
Page 5 of 10 1, 2, 3, 4, 5, 6, 7, 8 ... 10
