- Posted on
Sat Jan 17, 2015 7:42 pm
philipbasile
offline
Does anyone know why I would be getting the following in my event log over and over even though I don't have debugging turned on ?
Yet Another Nest Thermostat Plugin Invalid message: "switch_system_off":false,"local_ip":"192.168.2.106","away_temperature_high":26.528,"y2_type":"unknoe":"gas","compressor_locktive":false,"rssi":55,"emer_heahas_x2_cool":false,"ob_orientation":"O","cooling_x2_delivery":"unknown","available_loca1AB41120CY7","has_x2_alt_heat":false,"leaf_threshold_heat":2ed":true,"country_code":"US","fan_timer_timeout":0,"target_humidity":40,"heow_enabled":true,"filter_changed_date":1405396800,"hvac_safety_shutoff_active":false,"heat_pumfalse,"heater_delivery":"forced-air","radiant_control_enabled":false,"auto_away_reset":false,"away_temperature_low":20_address":"18b43002c172","heat_x2_source":"gas","fan_duty_start_time":0,"time_to_target":0,"backplate_model":"Backplate-2.5","heat_link_connection"oning_active":false,"topaz_enhanced_auto_away_enabled":false,"name":"Home","postal_code":"08527","creation_time":1354242432840,"num_thermostats":"2","away_setter":1,"structure_area":35{"$version":32217,"$timestamp":1421206503628,"heatpump_setback_active":false,"touched_by":{},"emer_heat_enable":false,"switch_system_off":false,"local_ip":"192.168.5.178","away_temperature_high":26.667,"y2_type":"unknown","tempera_cooling_state":false,"heater_source":"gas","compressor_lockout_leaf":-17.8,"has_x3_heat":false,"target_humidity_enabled":false,"heat_x3_source":"gas","alt_heat_delivery":"forced-air","fan_mode":"auto","has_x2_heat":false,"sunlight_correction_active":false,"rssi":58,"emer_heat_delivery"cription":"none","heatpump_savings":"off","humidity_control_lockout_end_time":0,"filter_reminder_level":0,"filter_reminder_enabled":true,"capability_level":4.31,"schedule_learning_reset":false,"has_x2_cool":false,"ob_orientation":"O","hvac_pins":"W1,Y1,C,Rh,G,Star","cooling_delivery":"unknown","range_enable":true,"dual_fuel_breakpoint_override":"none","autoy_temp_enabled":true,"has_fan":true,"dehumidifier_state":false,"nlclient_state":"","emer_heat_source":"electric","heatpump_ready":false,"cooling_x2_delivery":"unknown","available_locales":"en_US,fr_CA,es_US,en_GB,fr_FR,nl_NL","current_version":"4.3.3","learning_state":"slow","has_fossil_fuel":true,"pin_rh_description":"power","pin_ob_description":"none","safety_temp_activating_hvac":false,"has_alt_heat":false,"fan_duty_cycle":3600,"pin_y1_descri"gear_threshold_high":0,"backplate_serial_number":"02BA0FABE51201W5","has_x2_alt_heat":false,"leaf_threshold_heat":21.04,"heat_x3_delivery":"forced-air","is_on_stand":false,"learning_mode":true,"has_emer_heat":false,"leaf_learning":"ready","has_aux_heat":false,"aux_heat_source":"electric","filter_changed_set_date":1420984277,"backplate_bsl_info":"BSL","sunlight_correction_ready":true,"alt_heat_x2_source":"gas","pin_c_description":"power","humidifier_type":"steam","pin_w2aux_description":"none","humidity_control_lockout_start_time":0,"sunlight_correction_eout":0,"target_humidity":35,"heat_x2_delivery":"forced-air","gear_threshold_low":0,"lower_safety_temp":4.444,"last_software_update_utc_secs":1416413993,"cooling_x2_source":"electric","equipment_type":"electric","heat_pump_aux_threshold":10,"alt_heat_x2_delivery":"forced-air","heat_pump_comp_threshold":-31.5,"learning_days_completed_cool":0,"backplate_bsl_version":"2.1","current_schedule_mode":"HEAT","hvac_wires":"Heat,Cool,Fan,Common Wire,Rh,Star","fan_duty_end_time":0,"leaf":false,"type":"TBD","pin_g_description":"fan","click_sound":"on","aux_heat_delivery":"forced-air","away_temperature_low_enabled":true,"filter_changed_date":1421298000,"hvac_safety_shutoff_active":false,"heat_pump_comp_thrmidifier":false,"fan_cooling_enabled":true,"leaf_away_high":28.88,"fan_cooling_readiness":"ready","temperature_scale":"F","device_locale":"en_US","preconditioning_active":false,"maint_band_upper":0.279,"error_code":"","battery_level":3.888,"fan_control_state":false,"away_temperature_high_enabled":true,"learning_days_completed_heat":58,"humidifier_fan_activation":false,"upper_safety_temp_enabled":false,"pin_star_description":"hum","preconditioning_enabled":true,"dual_fuel_breakpoint":-1,"current_humidity":24,"postal_code":"08527","alt_heat_source":"gas","backplate_mono_version":"4.0.26","aux_lockout_leaf":10,"has_heat_pump":false,"heater_delivery":"forced-air","radiant_control_enabled":false,"auto_away_reset":false,"away_temperature_low":20.981,"temperature_lock":false,"has_air_filter":true,"upper_safety_temp":35,"time_to_target_training":"ready","dehumidifier_type"":0,"fan_timer_duration":900,"temperature_lock_low_temp":20,"pin_w1_description":"heat","forced_air":true,"temperature_lock_pin_hash":"","auto_dehum_enabled":true,"leaf_type":1,"backplate_mono_info":"TFE (BP_D2) 4.0.26 (root@bamboo) 2014-07-02 14:37:01","star_type":"hum","has_dual_fuel":false,"maint_band_lower":0.39,"learning_time":1710,"creation_time":1368405819647,"has_humidifier":true,"learning_days_completed_range":0,"dehumidifier_orientation_selected":"unknown","leaf_schedule_delta":1.11,"logging_priority":"informational","user_brightness":"medium","leaf_away_low":22.15,"pin_rc_description":"none","serial_number":"02AAw1AB4E120RKN","auto_dehum_state":false,"mac_address":"18b4770715cb","heat_x2_source":"gas","fan_duty_start_time":0,"time_to_target":0,"backplate_model":"Backplate-2.5","heat_link_connection":0,"model_version":"Display-2.6","heat_pump_aux_threshold_enabled":true,"ob_persistence":true,"schedules":[],"auto_away":1,"auto_away_learning":"training","hvac_heat_x3_state":false,"compressor_lockout_enabled":false,"hvac_alt_heat_state":false,"target_temperature_type":"heaimeout":0,"hvac_cool_x2_state":false,"target_temperature_high":24,"hvac_aux_heater_state":false,"hvac_heat_x2_state":false,"target_temperature_low":20,"target_temperature":22.15,"hvac_ac_state":false,"hvac_fan_state":false,"target_change_pending":false,"name":"Downstairs","current_temperature":21.93,"hvac_alt_heat_x2_state":false,"can_cool":true,"72ff2c80-3a95-11e2-bbdc-1231390f0261":{"$version":291,"$timestamp":1421197434767,"touched_by":{"touched_by":1},"dr_reminder_enabled":true,"location":"Jackson, NJ","renovation_date":"2000","country_code":"US","measurement_scale":"imperial","away_timestamp":1421020404,"hvac_safety_shutoff_enabled":true,"time_zone":"America/New_York","away":false,"house_type":"family","eta_preconditioning_active":false,"topaz_enhanced_auto_away_enabled":false,"name":"Home","postal_code":"08527","creation_time":1354242432840,"num_thermostats":"2","away_setter":1,"structure_area":357.677,"user":"user.163504","devices":["device.02AA0AAB41520LPP","device.02AB01AB251201KN"],"swarm":["device.02AA02AFGB120LPP","device.02012B45212202KN"],"fabric_ids":[],"clutches":[]},"serial":"02AA334WB451202KN"}
