Aside from the errors I noted in the "Nest Plugin available" thread the plugin is working great.
I'm planning to use W2 - Stage 2 Heat to control an Electric Space Heater via a Z-Wave'd outlet.
I figured I would need a MIMOLite to get the trigger from the NEST but if I can get a Status Change via the Plugin that Stage2Heat is on/off then the MIMO would not be required.
Possible/Feasible?
